Fog lights
Fog lights
Heya guys I have a 2009 Lancer es with no fog lights I’m thinking off buying fog lights for my car not sure if my car can have them just seeing if it’s possible this looks like the best place to ask
Re: Fog lights
You need to change the indicator stalk from memory and add the fog lights and then using some weird actions involving the door etc you can activate them in the ECU, there is a write up in the threads about it.
No longer own a lancer, Fairwell.
Re: Fog lights
You can get away with out modify the ETACS box and replacement of the indicators stalk
You can use a relay and use the positive off the parking lights to trigger the relay and power up the fog lights.
Works for me and others
More projects to come
Abdullatif
Re: Fog lights
I got this tutorial saved.
https://www.evolutionm.net/forums/lance ... ights.html
I'm in the same situation, i would like to install them, but didn't have enough time. I will try to install them when i get back but i hope this tutorial helps !!
Re: Fog lights
That's a great how to. I doubt you will go wrong with it.let us know how it all pans out
Re: Fog lights
If you're after a plug and play solution grab these off ebay. its the genuine kit and comes with everything you need :
https://www.ebay.com.au/itm/MITSUBISHI- ... 2438552170
then check out this thread on how to active them without a trip to the dealers :
viewtopic.php?f=21&t=21989
and here's a happy camper that proves that it does indeed work!
viewtopic.php?f=27&t=22120
Users browsing this forum: Majestic-12 [Bot] and 14 guests
