Hi all ,
i bought a ralliart 2011 back 6 months ago and have been looking at some new mods for the car
So far this is what i have done:
• Dump pipe 3" xforce exhaust with hi-cat
• GFB TMS respnse BOV
• Single Map tune
• 3 port Boost solenoid
• Evo x injectors OEM mitsubishi
• after market UICP
• Will be getting an EVO x intercooler next with plazaman LICP
My next mods that im looking at getting next
• Cold air intake system ( preferred AEM airbox )
• E85 tune with upgraded fuel pump (if needed)
What do you guys suggest i should do next ? or is there something i need to be careful of >?
Appreciate it......
Mods ralliart 2011
Mods ralliart 2011
2014 Evo x GSR
K&N Typhoon CAI
Grimspeed 3 port
Nvidia N1 dual cat back
Fab test pipe & Dump
Turbosmart wastegate
Re: Mods ralliart 2011
You have all the bits to make it go fast in a straight line. How about bits to make it go fast around the corners?
Sorry i forgot to mention i do have BC coil-overs also. Unless there is something else ?
2014 Evo x GSR
K&N Typhoon CAI
Grimspeed 3 port
- bunnishiwa
Nice. Remember to get it tuned when you change the intake
Should be pushing 180kw at the wheels once you get the intercooler installed.
If tuning is your thing check out the ralliart forums for ecuflash on evolutionm site
For e85 you'll definitely want a new fuel pump (https://www.maperformance.com/collectio ... 9-651-1026) is the one I was looking at for a long while, along with the flex fuel kit. Guy called Tephra on evom has done a mod called Tephra mod v3 which has a variable map to work with a flex fuel kit so you'll never get stuck worrying about fuel mixes
Let us know how you go
- Lowered on Kings
- Whiteline Rear Swaybar
Noli Timere Messorem
- Lowered on Kings
Thanks definetly look into it , i think that was one of my concern in regards to fuel mixtures. So far doing 191 kw hoping to stretch to 220-230kw with E85
2014 Evo x GSR
K&N Typhoon CAI
Grimspeed 3 port
Users browsing this forum: No registered users and 88 guests
