Fuel Cap not opening when pulling lever?
Moderator
Moderator
Postby Mystique » Fri Apr 20, 2018 2:18 pm
Sooooo. On my partners 08 ES, he noticed today while going to fill up that his fuel cap won’t open at all while pulling the lever.
After having to leave the servo and come home, we managed to get it open by me holding the lever and him managing to pull the cap open,
Has anyone had this issue at all?
Online
Re: Fuel Cap not opening when pulling lever?
Postby lancerdarryl » Fri Apr 20, 2018 6:17 pm
Cable may have stretched a little.Have a look at both ends and make sure the cable retaining brackets haven't bent causing the cable to go slack.
AJjnr86
Postby AJjnr86 » Fri Apr 20, 2018 6:18 pm
Hyundias have that issue a lot, the pivot point gets dirty and gummed up and need to be cleaned with brake cleaner then lubricated with wd40 or the like.
Also make sure the release spring isn't broken or weak
OHH YEA!!!!
Postby Lancer1993 » Fri Apr 20, 2018 6:50 pm
I'd check the little spring thing that pops it open, maybe its broken?
http://www.clubcj.net/workshop/SEARCH/i ... B00ENG.pdf
Postby aspir3 » Sat Apr 21, 2018 3:48 pm
I would think the cable needs adjusting.
I've never heard of the issue with lancers
sarusa
Postby sarusa » Sun Apr 22, 2018 11:18 am
lol Try checking from in the boot may give you an indication of your problem.
Postby Lancer1993 » Sun Apr 22, 2018 12:02 pm
OT - why do they still put the boot and fuel openers next to each other?
At least its not as bad as some cars having the pull hand brake and bonnet release in the same spot!
Moderator
Moderator
Postby Mystique » Sun Apr 22, 2018 7:46 pm
Lancer1993 wrote:OT - why do they still put the boot and fuel openers next to each other?
God knows haha!
I will check it out though, thanks for the info, I was reading on an Evo forum when I originally googled it that it was a common problem, although given the fact that the car has 200K on it, might be why it's now having issues haha.
Postby Lancer1993 » Mon Apr 23, 2018 7:21 am
My old 93' Lancer never had this issue, only problem I have some times is the fuel cap becoming hard to unscrew, put some grease on it and it works fine now.
