New Member - service manual anywhere?
varagner
Postby varagner » Wed Jan 24, 2018 3:00 pm
Hi,
My fiancee has a CJ lancer, have been doing the servicing etc on it for a while.
Just wondering if their is a copy of the technician's service manual floating around?
If anyone wants the sob story why:
Got quoted $1500 to replace the ABS module and pump, car has C2116 code, has been having the ABS + Check engine light come on for occasionally for a little while but has been getting rather frequent now.
Being reasonably handy I quickly googled things and discovered I could refurb the unit for $500 or pick up a second hand one for far less.
Thinking I will get a second hand unit (then I have a spare to send of to refurb if the issue occurs again), just would ideally like the tech manual to save reinventing the wheel by figuring it out myself.
sarusa
Re: New Member - service manual anywhere?
Postby sarusa » Fri Jan 26, 2018 7:10 am
Only manual as such is on disc from Mitsubishi and they of course want a premium price.
I thunk there still is a disc manual available on here somewhere. Not sure but might only be available
to paid up premium members. :)
Postby lancerdarryl » Fri Jan 26, 2018 8:02 am
You can pick up CD copies on EBay for around $35.Easiest fix on the ABS pump is to get your own unit repaired.A secondhand one is likely to fail at sometime.
Users browsing this forum: Google [Bot] and 72 guests
