*CLOSED* Magnetic Car Bra Hood Mask
For all ClubCJ Members.
Postby bd-850 » Wed Aug 12, 2009 9:22 am
I sent the guy an email and he can drop the price to $52.00 (about $62au) from $54.95 but we have to get 5 orders, and im sure if we get a few more he might drop the price more.
The 2008+ Mitsubishi Lancer Magnetic Car Bra Hood Mask is made from a safety-coated, flexible magnetic sheet. It is UV-resistant vinyl on the outside and magnetized rubber underneath. This material is also used for magnetic car signs and the seal around your refrigerator door. The safety-coated material was designed to be used on cars and after many years of use it has been proven to give problem-free service with almost no maintenance.
Conventional Car Bras can damage your paint. They trap road grit, which will scratch and eventually wear through the paint. They also get wet, and, as the water dries, it causes the paint to oxidize and fade. This damage can only be repaired by repainting the hood. It is difficult and time-consuming to clean road grit and then wait for the bra to dry. The only way to prevent damage from long-term use of a conventional bra is to clean and dry it frequently - as often as every few days.
The flexible Magnetic Bra sheet forms a tight seal that keeps out water and grit. It will not cause abrasion or oxidation. The Magnetic Car Bra can be left on a car permanently with only a few minutes of maintenance per month. All that is required is to wipe underneath with a damp cloth - once a month, that's it.
The Monsoon Magnetic Car Bra has a patented design that makes it theft-proof and secure at any speed. It uses a durable U-shaped edge trim that covers the leading edge and sides of the bra. This prevents wind and water from forcing their way under the bra at high speed and prevents removing the bra without opening the hood.
Flexible magnetic sheet precisely follows the contours of the hood. The finest detail will show through. It will make your car look great, on or off.
http://autocityimports.com/2008-mitsubi ... -8271.html
Postby bd-850 » Wed Aug 12, 2009 9:23 am
i possible would get 3 (2 for other cars)
Postby LZY_EYE » Wed Aug 12, 2009 9:24 am
As ugly as that is, I would probably consider one... bonnet gets hammered going up and down the freeway!!
Postby bd-850 » Wed Aug 12, 2009 9:30 am
i think they look better than the "normal" car bras, but i would only have it on when i go for long drives. and its easier to put on than the other bras. and it covers where 99% of my stone chips are
Postby LZY_EYE » Wed Aug 12, 2009 9:31 am
Definitely, those full car bras are ugly!!
What sort of price is the freight for these?
Postby bd-850 » Wed Aug 12, 2009 9:39 am
that i forgot ask, will send an email, will put up when i get a repley
vi93r
Postby vi93r » Wed Aug 12, 2009 11:12 am
I would be interested in one. would of come in handy over the last few weeks, can count the chips on 2 hands in the area the bra covers now..
My Rides Mod Thread
CCJ Premium Member #0100.
Superintendent Chalmers
Postby Superintendent Chalmers » Wed Aug 12, 2009 11:57 am
I'm not really sure what that bra is for????? What is it protecting??? Wouldn't the one that goes around the headlight front be better for avoiding stone chips??? It seems like it protects only a little section that shouldn't be getting much damage in the first place!
Lethal_1
Location: Sth Side Of Brisbane, Here @ Springwood, Qld, Australia.
Postby Lethal_1 » Wed Aug 12, 2009 12:04 pm
WHOA.? :shock:
- That sort of looks awesome.? 8)
- I'm definitely *interested* ... Depending on fit.?
I have a Ralliart ... How does this fit the RA with the " Bonnet-Vents " etc.?
Image Image
ClubCJ Lifetime Member #0098
NA AUTOSPORTS AND ENGINEERING - 3808 3048
Postby LZY_EYE » Wed Aug 12, 2009 12:09 pm
Comparing the 2 pics, I would say it would fit but can't be sure. Might need to contact the supplier and double check I think.
Speedie
Postby Speedie » Wed Aug 12, 2009 12:09 pm
Would it stick to a RA Bonnet?? Yours are alloy and the Lancers isn't
vi93r
Postby vi93r » Wed Aug 12, 2009 12:36 pm
From current experience, where the cover is, is exactly where the stones hit. The plastic bonnet protector would be missed by the stones that I have tagged so far.
How the stones that hit the bra behave would be interesting, as at speed without it the stones bounce off the bonnet into the windscreen. (only managed the one thats left a decent chip so far)
Edited for punctuation even I had issues rereading it...
Josh_Emerton
Postby Josh_Emerton » Wed Aug 12, 2009 12:53 pm
Speedie wrote:Would it stick to a RA Bonnet?? Yours are alloy and the Lancers isn't
"Insert" alloy is still a metal. The actual word alloy means its mixed.
i.e. Titanium alloy might be 90% ttanium, 10% something else.
Bandit
Postby Bandit » Wed Aug 12, 2009 2:34 pm
Ralliart bonnet is aluminium as far as I know, which isn't magnetic - so it won't work...
ClubCJ's first Sportback
Klue2k
Postby Klue2k » Wed Aug 12, 2009 2:37 pm
if the car bra is just magnetic, won't someone just be able to rip it off?
