Headlight wiring loom
Masochist
Postby Masochist » Thu Aug 03, 2017 8:06 am
Hey guys,
Just wondering if anyone knows what the extra plug on the headlight wiring loom is used for. There the the main harness plug with the orange internals which controls indicator, hi/low beams etc, but i cant figure out what this 2nd plug is.
I have just replaced my headlights, new ones have an accessory wire for DRL. And just wondering whether this plug controlled the crappy led on the oem headlights.
Will add a photo later (too large from phone so need to adjust sizing.)
Re: Headlight wiring loom
Postby aspir3 » Thu Aug 03, 2017 9:21 am
Model and year may help too.
Postby lancerdarryl » Thu Aug 03, 2017 4:54 pm
2nd plug is used in the factory HID lights,it controls the turning motor and the self levelling motor.
Postby bumblebee » Thu Aug 03, 2017 7:19 pm
Very handy to know. Thanks for the info
Masochist
Postby Masochist » Thu Aug 03, 2017 8:10 pm
Before i go testing, does anyone know if these are constant or switched power? Having aftermarket headlights and never having the leveling motors i dont really need the oem leveling motor cabling anymore ... but would like it to power my DRL if possible. If its constant from engine on they make lige a lot easier
Masochist
Postby Masochist » Thu Aug 03, 2017 8:25 pm
The new headlights installed
Ronan.Butler11
Postby Ronan.Butler11 » Thu Aug 03, 2017 8:48 pm
lancerdarryl wrote:2nd plug is used in the factory HID lights,it controls the turning motor and the self levelling motor.
wait... there is a HID loom in the CJ's already?? meaning plug and play for any projectors?
or am i completely misunderstanding this
'09 Lancer VRX
Modifications:
18" King Rims
Ralliart Snorkel
Postby lancerdarryl » Thu Aug 03, 2017 11:01 pm
The plugs may be there but probably don't work.There will be relays missing and additional wiring looms inside the car missing also.
Postby bumblebee » Fri Aug 04, 2017 6:52 am
Masochist wrote:Image
Very sexy indeed
Are they ADR approved?
Masochist
Postby Masochist » Fri Aug 04, 2017 8:52 pm
Very sexy indeed
Unsure, asking the company i purchased from for confirmation. I dont see why not, they arent HID/LED conversions for headlights only projector conversion ... still using halogen globes (for now, til i can source some 'legal' conversion kits), and the DRL is ccfl not LED so again ... doesnt require automatic leveling/cleaning like hid/led DRL lights.
Postby bumblebee » Sat Aug 05, 2017 6:29 am
If they are ADR compliance then its a mod i would certainly consider down the track for sure. Can i trouble you please for info on where to purchase these.
Thanks
Masochist
Postby Masochist » Sat Aug 05, 2017 7:45 am
bumblebee wrote:If they are ADR compliance then its a mod i would certainly consider down the track for sure. Can i trouble you please for info on where to purchase these.
Thanks
http://www.ebay.com.au/itm/232152444777
Or direct from supplier page
http://www.ctautoparts.com.au/3d-neon-l ... ion-x.html
Masochist
Postby Masochist » Sat Aug 05, 2017 8:09 am
Pretty sure it is
We ve sold more than 100 sets all over differs state
Never had any issue
Best regards,
CT Autoparts Pty. Ltd. Australia
Unit 14/ 367-369 Victoria Street, Wetherill Park 2164, Sydney, NSW , Australia
Tel: +61-2-9756 0138
Mob: +61 -405 924 864
Website: www.ctautoparts.com.au
Response from the guys that sold it. I will update if i find out otherwise
Postby lancerdarryl » Sat Aug 05, 2017 10:29 am
"Pretty sure it is".....that says to me they aren't ADR compliant.If they were then the answer would have been "Yes".
Shaun Patterson
Postby Shaun Patterson » Sat Aug 05, 2017 3:28 pm
Very sexy indeed
there is no LEGAL hid conversion kits, for HID to be legal you need autoleveling projectors and headlight washers,, the leveeling is also impossible to retrofit and require so man gyros and sensors
Return to “Electrical”
