Used Meguiars for years almost half a century, Wet Look, which was a polymer polish but is now a wax. Meguiars do still produce a polymer polish
but was told by Australian distributors they don't import it. Neither Autoglyn or anyone else appear to have a polymer polish, except Nu Finnish, which I find, not as good. For me. goodby Meguiars!!!
Now found and use, show car finish, polymer polish. Zaino pro 2 for a magic wet look finish, gained with so little effort.
Lasts up to 4 months or more. Just put a smear on a polishing pad that will be enough for a full panel, wipe lightly
with straight line action. Let dry for more than fifteen minutes, do the whole car if you like, and lightly wipe off. Easy! And Wow
Don't use more than a small amount. If you wish, wax the car first and put Zaino over the top and experience the improvement.
Can and I have used Zaino over rubber and vinyl, even hoses under the bonnet, brings them up to a nice shine, works a treat!
Non abrasive, and UV protective qualities. Look up Zaino on the internet. You don't have to use two or more products at the same time
as suggested on the internet unless you want to. Zaino pro 2 works fine by itself as told to me by my state Vic, vendor distributor. There's one in each state.
Just Zaino pro 2 works better and is easier to apply then anything else I've ever used before. Want a better finish? Give it a second coat.
more than 24 hours after the first! Rub your hand over the finished job and feel it glide over.
POLYMER POLISH
- lancerdarryl
Re: POLYMER POLISH
Sounds like a good thing.Where did you purchase yours from?
Re: POLYMER POLISH
lancerdarryl wrote:Sounds like a good thing.Where did you purchase yours from?
Got mine delivered from Zaino at Tullamarine Vic: phone (03)9330 2048, they have an outlet in each state. Ring this number for your state outlet or just get contact Zaino number for your state on the internet, also interesting application video's on internet.correct name of Product Zaino Z2 pro.
- lancerdarryl
Re: POLYMER POLISH
Thanks,I'll give them a call
Re: POLYMER POLISH
lancerdarryl wrote:Thanks,I'll give them a call
Did you finish up getting Zaino and whats your opinion if you did.
- lancer2014
- Lancer ES/EX
Re: POLYMER POLISH
If you want greater brightness and durability use jetseal you have a year of protection
evo x turbo kit
RRM crank pulley
Magnaflow cat back 2.5
Tein Flex Z Coilovers
MR BBS Rims
RRM crank pulley
MR BBS Rims
