TRANSMISSION COOLER
sarusa
TRANSMISSION COOLER
Postby sarusa » Sun Feb 26, 2017 9:08 am
Is it worthwhile fitting a transmission cooler for a CVT for std NA set up, presuming it has a pipe running through the radiator already.
Normal day to day driving occasional long trip, self plus one passenger. :?
Will it be necessary or beneficial on a std NA set up, also any recommendations re type and brand.
Re: TRANSMISSION COOLER
Postby aspir3 » Sun Feb 26, 2017 11:12 am
I believe they all should have coolers fitted in our harsh Australian conditions. It will save the life of the oil.
Some early models were fitted coolers as standard. I personally would look for a second hand unit at the wreckers and fit it rather than an aftermarket unit.
sarusa
Postby sarusa » Thu Mar 02, 2017 7:48 am
One thing about the CVT, it creates its own limits as to how hard it can be pushed.
So other than for, towing, heavy lodes and really hard driving with steep inclines, should be OK.
