Cenral Jacking Points
sarusa
Postby sarusa » Wed Nov 09, 2016 8:07 am
Simple I know, but unsure. Where are the central jacking points, front and rear, on the NA cars'
Pictures if possible, would be a great confidence booster. :?
Re: Cenral Jacking Points
Postby lancerdarryl » Wed Nov 09, 2016 8:18 am
The front jacking point is on the engine/ gearbox crossmember if you look at it you will see a square section in the undertray.It is slightly to the left side(your right looking at the car) of the cars centre.As for the rear,I use the section of body where the lower rear control arms mount into the chassis.If you have a tow bar then you can go straight under where the gooseneck bolts onto the tow bar.
