Hi All
Does anyone know the Torque settings for the two bolts that holds the Disk Rotors in place and the two bolts that hold the disk pads in place?
Many thanks
Brake Torque setting ???
Re: Brake Torque setting ???
Used to be able to access service manual here:
http://clubcj.net/viewtopic.php?t=8528&highlight=workshop+manual
But it no longer works.
For the caliper assembly it's 100 Nm +- 10 (74 ft-lb +- 7).
For the caliper bolts I can't seem to find it in the service manual as it no longer works with windows 10, but off memory it should be ok as long as it's tight enough, it doesn't hold anything down just provides pins for the caliper to slide over.
