This might be a complete numpty question, but does the switch MN108721 (Sonar) fit on the panel on the right of the steering wheel?
I had front sensors installed, and the switch is just a toggle on/off and doesn't look the best (plus gets hot with the lamp on it), so thought MN108721 might be cool.
Not sure of the depth of the switch (or the cavity) but my electrical guy would do the install - just thought I'd check if others had two cents to throw in?
MN108721 on dash to right of steering
