Wiring diagram
Jona
Wiring diagram
Postby Jona » Tue Feb 09, 2016 1:50 am
Hi,
I'm looking for a wiring diagram for my Lancer (2011 1,6L). I found this:
http://www.clubcj.net/workshop/SEARCH/2008/index_M1.htm
Is this universal for Lancer from 2008 till 2014? Since this is a 2008, will it be the same as for my 2011?
Just wondering. It would help me alot if I could locate correct wiring diagrams!
Thanks!
2011 lancer CY 1,6L Cleartec
CY1A / 4A92
Postby aspir3 » Tue Feb 09, 2016 5:44 am
That is correct for the Australian model at the time. Some later models had additional wiring added.
If you want it for cruise control then that should work as the 2008 model had cruise control.
Jona
Postby Jona » Tue Feb 09, 2016 6:51 am
Thank you for your response!
As additional info I just found this:
http://www.roadraceengineering.com/evox/tech/evox-ecuwiring.htm
Just took a look under my hood, and apperantly I'm lacking wiring in my harness to my engine ECU on pins 95, 107 and 108. (the ECU has the pins, the harness just lacks the wires. The 4A92 should be able to configure cruise control in the ECU, however the 4A91 is not. Luckily I know for sure I have the 4A92)
I need to figure out a way how to add wires to those pins, or get a donor engine ecu harness from somewhere ...
Any ideas?
CY1A / 4A92
Postby aspir3 » Tue Feb 09, 2016 7:01 am
Try wreckers, often you will have to buy the complete wiring loom rather then just the section you require
Return to “Electrical”
