New member need advice with Rockford Issue
Hi guys from country SA, trying to get some info on aftermarket head unit install with Rockford fosgate system, bought an aerpro harness CHMB1C and it wont turn on the amp, has anyone bought this harness before, I know the Mito-02 but hear some issue with that and also needs a separate steering wheel adaptor, anyone have any info please! thanks
- dananjaya.herath
- Lancer Learner
Re: New member need advice with Rockford Issue
morry0 wrote:Hi guys from country SA, trying to get some info on aftermarket head unit install with Rockford fosgate system, bought an aerpro harness CHMB1C and it wont turn on the amp, has anyone bought this harness before, I know the Mito-02 but hear some issue with that and also needs a separate steering wheel adaptor, anyone have any info please! thanks
Hi did you solve the issue
- adamhumphrey
Make sure you have the amp turn on wire connected. When I installed Kenwood DVD into my wife's car the amp wasn't working and hooked up amp wire from Kenwood to the Aerpro Can bus kit there should be a wire on the MIT002
MY11 Evo X MR (2011-Current)
MY20 Asx GSR (2023-Current)
Users browsing this forum: No registered users and 89 guests
