Headlight Leveling - Wiring loom
Shaun Patterson
Postby Shaun Patterson » Sun Sep 13, 2015 7:54 pm
Hi guys i bought some oem projectors fitted with leveling motors and comes bundled with the leveling switch for an extra 150 ill add, and in my hast i overlook the fact the my ralliart doesnt have the 3 wires in the headlight connection needed for the levelling motor to function, has anyone managed to get it to work in a lancer that didnt come with the older harness?
SEB15
Postby SEB15 » Mon Sep 14, 2015 11:57 am
following
Swerve
Postby Swerve » Mon Sep 14, 2015 1:01 pm
So from what I understand you only need three wires. One for the Motor Drive, one for Voltage Comparison, and one for Ground. Ground is easy enough, but the other two are where it gets tricky. You should be able to get the wire for the "Motor Drive Circuit" on Pin 5 of C-130, and the one for the "Voltage Comparison Circuit" on Pin 3 of C-131. I'm assuming these are blanked out/not available to you.
Someone correct me if I'm wrong, I believe in Australia the leveling motor will not work on Lancers as we are missing all the sensors/wiring on the car. Though you can check the back of your headlights and adjust the light output using the adjustment screws.
Sorry I'm at work I'll have a better look at home.
Postby himynameisdaniel » Mon Sep 14, 2015 1:53 pm
Check the main headlight connector harness. if it has cables to all the individual connectors then everything should be plug and play.
Shaun Patterson
Postby Shaun Patterson » Mon Sep 14, 2015 8:13 pm
thats what i mean, it has the 3 wires required for the leveling motors blanked out
Shaun Patterson
Postby Shaun Patterson » Mon Sep 14, 2015 8:15 pm
the older lancer do have all of the wireing necesary, and in the cabin i have the loom for the switch already there just not in the engine bay
Postby JustinR » Mon Sep 14, 2015 8:19 pm
Shaun Patterson wrote:Hi guys i bought some oem projectors fitted with leveling motors and comes bundled with the leveling switch for an extra 150 ill add, and in my hast i overlook the fact the my ralliart doesnt have the 3 wires in the headlight connection needed for the levelling motor to function, has anyone managed to get it to work in a lancer that didnt come with the older harness?
Are you saying the Ralliart doesn't have the three wires and the NA's do?
Shaun Patterson
Postby Shaun Patterson » Mon Sep 14, 2015 8:22 pm
i think they all stop from my10 onwards
Swerve
Postby Swerve » Tue Sep 15, 2015 1:26 am
I haven't had a look was too tired after work. As far as I know in Australia most newer models of NA Lancers, RA's and the Evo GSR don't have the wiring in the engine bay.
Some pictures of the headlights, harness and switch might help.
My advice is either use the adjustment screws on the headlights to change the level.
Alternatively see if you can get the wired from somewhere else (ETACs?) and splice into it. As stated earlier you need will need three wires. One for Motor Drive, one for Voltage Comparison and one for Ground.
The first wire Motor Drive would just need a 12V power supply to drive the motor. Have a look on the headlight wiring loom/harness in the engine bay, one of those wires will be a constant source of 12V which you can splice into. Try Pin 2, otherwise just locate which wire is 12V or get it from another source.
Ground is pretty self explanatory.
The Voltage Comparison wire needs to be spliced into the input signal wire on the connector/loom or Pin 4? On the switch.
It's late and I could be way off the mark but that's my thoughts.
Shaun Patterson
Postby Shaun Patterson » Tue Sep 15, 2015 8:03 am
ill get some photo, the only reason i got these lights over other was because of the levelling motor,
i will get some photos this arvo
what you have suggest sounds like a good place to start tho
SEB15
Postby SEB15 » Wed Sep 16, 2015 7:02 am
checked mine and i do have the plug, is a 09 MY10 RA :)
Swerve
Postby Swerve » Wed Sep 16, 2015 8:06 am
Can you take a photo of the plug? I had an issue with a broken wire in my headlights and while in that area of then engine bay I'm 90% sure I also have the plugs if I'm thinking of the right ones.
Shaun Patterson
Postby Shaun Patterson » Wed Sep 16, 2015 6:15 pm
i have all of the plugs just missing 3 wires on the big one
Gtrain
Re: Headlight Leveling - Wiring loom
Postby Gtrain » Tue Jan 16, 2018 6:48 pm
bump on old thread but did anyone get this sorted?
Shaun Patterson
Postby Shaun Patterson » Wed Jan 17, 2018 8:36 am
Gtrain wrote:bump on old thread but did anyone get this sorted?
nope faqr to much effort and the oem headlights cost an arm and a leg its hardly worth it
Users browsing this forum: Bing [Bot] and 6 guests
