Hello from brisbane
Hello from brisbane
Hi everyone, my name is Marek from Brisbane and I own my now 3rd evo which is 2010 Blue Evo X GSR. Had the car for about a year now and since bone stock form I made all the mods in my signature. Car is self tuned and all work on the car is done by my self. I'm looking forward to share my knowledge and learn some new things from you guys.
2010 Evo X GSR SST
3"CBE
UICP
Turbosmart BOV
Turbosmart 24psi Actuator
UR Itecooler
DW65c Fuel pump
ID1000 Injectors
Grimm Speed 3 Port
Cosworth Air Filter
210kw on 98
240kw on Eflex
1/4 12.4
3"CBE
UICP
Turbosmart BOV
UR Itecooler
DW65c Fuel pump
ID1000 Injectors
Grimm Speed 3 Port
Cosworth Air Filter
210kw on 98
240kw on Eflex
1/4 12.4
Venture started with galant vr4 then onto 8gsr then 8mr and now the x. Hopefully i wont go crazy stupid on this car as i did with my 8mr.
very happy with the car as is so time to enjoy the car on the road and not on car stands in the garage:)
2010 Evo X GSR SST
3"CBE
UICP
Turbosmart BOV
UR Itecooler
DW65c Fuel pump
ID1000 Injectors
Grimm Speed 3 Port
Cosworth Air Filter
210kw on 98
240kw on Eflex
1/4 12.4
3"CBE
UICP
Turbosmart BOV
UR Itecooler
DW65c Fuel pump
ID1000 Injectors
Grimm Speed 3 Port
Cosworth Air Filter
210kw on 98
240kw on Eflex
1/4 12.4
Haha trust me been there and done that and it's not as pretty as people might say. Once you mod majority of parts any small failure can cost big dollar. For instance faulty injector cost me 2000k old built motor. Not to mention all the extra stress you put on driveline.
2010 Evo X GSR SST
3"CBE
UICP
Turbosmart BOV
UR Itecooler
DW65c Fuel pump
ID1000 Injectors
Grimm Speed 3 Port
Cosworth Air Filter
210kw on 98
240kw on Eflex
1/4 12.4
3"CBE
UICP
Turbosmart BOV
UR Itecooler
DW65c Fuel pump
ID1000 Injectors
Grimm Speed 3 Port
Cosworth Air Filter
210kw on 98
240kw on Eflex
1/4 12.4
- kay christensen
- Post Monster
All comes down to torque and i your case using dynojet instead of mustang in virtual dyno will give you high reading to. Generally if youre on mustang you should keep the torque under 400nm
2010 Evo X GSR SST
3"CBE
UICP
Turbosmart BOV
UR Itecooler
DW65c Fuel pump
ID1000 Injectors
Grimm Speed 3 Port
Cosworth Air Filter
210kw on 98
240kw on Eflex
1/4 12.4
3"CBE
UICP
Turbosmart BOV
UR Itecooler
DW65c Fuel pump
ID1000 Injectors
Grimm Speed 3 Port
Cosworth Air Filter
210kw on 98
240kw on Eflex
1/4 12.4
I am curently going to about 420nm and then the turbo runs out of puff and torque drops down which keeps the sst hopefully in the safe zone but with those cars you just never know. Last weeken i changed my internal and extrenal sst filter and put new fluid in and wow what a difference it makes.
2010 Evo X GSR SST
3"CBE
UICP
Turbosmart BOV
UR Itecooler
DW65c Fuel pump
ID1000 Injectors
Grimm Speed 3 Port
Cosworth Air Filter
210kw on 98
240kw on Eflex
1/4 12.4
3"CBE
UICP
Turbosmart BOV
UR Itecooler
DW65c Fuel pump
ID1000 Injectors
Grimm Speed 3 Port
Cosworth Air Filter
210kw on 98
240kw on Eflex
1/4 12.4
