Looking at buying a second hand catback / HFC - Ideally maybe an UR catback?
Hit me up if you have one for sale or see one on gumtree etc
*Note: Not so much interested in LOUD exhaust ie borla etc
el3ment wrote:Try these guys. https://www.facebook.com/AKRacingAus
Trouble wrote:[quote:d7545b40d8=el3ment]Try these guys. https://www.facebook.com/AKRacingAus[/quote:d7545b40d8] Cheers mate - thats what im planning if i cant find any [i:d7545b40d8]second hand or used[/i:d7545b40d8] onesjust hoping someone wants to change theirs up or revert to stock! Fingers crossed
el3ment wrote:[quote:e3ace81ae2=Trouble][quote:d7545b40d8=el3ment]Try these guys. https://www.facebook.com/AKRacingAus[/quote:d7545b40d8] Cheers mate - thats what im planning if i cant find any [i:d7545b40d8]second hand or used[/i:d7545b40d8] onesjust hoping someone wants to change theirs up or revert to stock! Fingers crossed[/quote:e3ace81ae2] They might have some 2nd hand ones
Frizz wrote:If you dont want anything too loud the best one I found so far is the CP-E catback (I have one without the extra resonator). The videos online dont do it justice and with a X turbo it just gets deeper. UR is just as loud or even louder than the borlas apparently, I wouldnt recommend either of them if youre after something quieter. Free to check mine out if you like.
the sam wrote:Anything with a transverse muffler will work better at keeping noise down than straight through mufflers. So look for one with the large single rear muffler similar to the stock exhaust.
bunnishiwa wrote:Elliot - would you try just the HFC with stock muffler? Just changing the cat gives you more (tunable) power and also deepens the exhaust note a little. Could be a good place to start whilst you look?
the sam wrote:Yes that hyperflow looks good. It will still be loudish though! Might need another resonator in it to shut it up. If youre thinking of doing a high flow cat on stock exhaust, Id go for a 3 down pipe and 3 cat pipe as this will give the best gains and have it ready for more power when you want it. If you are thinking of keeping stock exhaust make sure you do the rear muffler mod to reduce restriction. MRT have a video on it where you cut the rear muffler open and remove a couple of the baffles before welding it back up. Works a treat and gives it a nicer note too. I have an aftermarket exhaust and Im almost considering going back to stock exhaust as its just too loud and I made great power on stock exhaust anyway...
