OIL TEMP ON RALLIARTS AND EVO X
CJ Lancer Turbo Performance Modifications & Information.
the sam
Postby the sam » Thu Apr 02, 2015 5:44 am
Couple of guys are running these on race cars with great success.
http://www.ebay.com.au/itm/B-M-SUPERCOOLER-ENGINE-OR-TRANSMISSION-OIL-COOLER-5-3-4-X-11-X-1-1-2-BM70273-/140790146196?pt=LH_DefaultDomain_15&hash=item20c7bf2494
You will have to figure out somewhere to fit the cooler though as we have the window washer bottle where the evos have the oil cooler stock, as well as getting some lines and fittings to connect it to the oil filter flange on the block:
May also need to add a thermostat where the black circle is as the oil will be flowing continuously through the cooler.
230kw/430nm @ 24psi on E85
12.191 @ 108.81mph - Fastest stock turbo ralliart in Australia
www.facebook.com/BoostinJuiceTuningSydney
www.clubcj.net/viewtopic.php?p=369141#369141
denzza
Postby denzza » Fri Apr 03, 2015 10:23 am
Evo X cooler should be fine. Straight fit with the bracket and lines. And yeah it sucks.... washer bottle is in the way LOL
FULL EVO X TURBO SETUP
BC RACING BR COILOVERS
PistenBoy
Postby PistenBoy » Fri Apr 03, 2015 5:17 pm
I was looking at that before... We can relocate or make the washer bottles smaller to be able to mount the cooler in the X spot.
PistenBoy
LiX
Postby LiX » Sat Apr 04, 2015 1:23 am
Thermostat is a must!
Regarding the washer bottle, you can always relocate it in the trunk like on the X.
Postby lancerdarryl » Sat Apr 04, 2015 8:01 am
LiX wrote:Thermostat is a must! Regarding the washer bottle, you can always relocate it in the trunk like on the X.
What about using the X headlight washer bottle as your windscreen washer bottle?
LiX
Postby LiX » Sun Apr 05, 2015 7:32 am
lancerdarryl wrote:What about using the X headlight washer bottle as your windscreen washer bottle?
It can be used, however it's too small in volume. I'm refilling it quite regularly.
denzza
Postby denzza » Mon Apr 06, 2015 11:55 am
Yeah thats what i got, the evo x headlight washer bottle. Sits nicely behind the evo x cooler.
Just the pump and wiring is different
Can anyone confirm if i snipped the wires off the washer pump plug to the evox headlight washer pump plug ?
Thanks
Postby lancerdarryl » Mon Apr 06, 2015 2:54 pm
Should work OK Denis,I think the headlight washer pump is a higher volume pump so you should have the best windscreen washers in town!
chris
Postby chris » Mon Apr 06, 2015 9:47 pm
Modern full-synthetic oils are ok to 150c or more
chris
Postby chris » Mon Apr 06, 2015 10:33 pm
GF-4 certified oil SM/SN/CJ4 oils have to pass the sequence 111G test with the oil at 150c for 100 hours at 3600rpm so I would`nt panic if you are using a decent oil .
denzza
Postby denzza » Sun Apr 19, 2015 2:44 pm
And all installed :)
Its working now
The actual oil temp sensor was out by 20 degree C.
Used a thermal infrared gun
Oil Thermostat is next but should be ok for now
Thanks everyone!
Return to “2008+ Turbo Performance”
