Hey guys,
Recently installed a oil temp gauge. And its reading 110c and when driving around 30 minutes. it goes to 120c.
I feel like this is way too high!
Does anyone have RA with a oil temp sensor ?
THinking i need an Oil cooler
Thanks guys
OIL TEMP ON RALLIARTS AND EVO X
FULL EVO X TURBO SETUP
BC RACING BR COILOVERS
- lancerdarryl
- lancerdarryl
- poe_sniper
- Lancer VR/GT
yeah i know that, but im just trying to figure out if any you RA owners actually know your oil temps ?
Could be like mine and not even know it ?
- poe_sniper
- Lancer VR/GT
To be honest I have no idea what my oil temps are. I don't think the RA even has an oil temp sensor?
I've tracked my car several times with about 250kw running through it and it hasn't missed a beat. I change my oil every 5000kms and it doesn't look completely stuffed and doesn't smell burnt so it mustn't be crazy hot.
- Zaphod
poe_sniper wrote:...I change my oil every 5000kms and it doesnt look completely stuffed and doesnt smell burnt so it mustnt be crazy hot.
There you have it!
Your engine oil will be above 100 degrees, so is your coolant; as poe-sniper says, check the colour, check the smell...
poe_sniper wrote:To be honest I have no idea what my oil temps are. I dont think the RA even has an oil temp sensor? Ive tracked my car several times with about 250kw running through it and it hasnt missed a beat. I change my oil every 5000kms and it doesnt look completely stuffed and doesnt smell burnt so it mustnt be crazy hot.
Yeah see i do oil changes every 5,000kms as well. I have never had burning smell or anything. Healthy as it can be !
Im using TOTAL QUARTZ 9000 5W40.
But i think oil cooler should do the trick. Just stucks to find out 2 years later its been running hot !
Also my coolant doesnt go over 85 degrees
- poe_sniper
- Lancer VR/GT
One of the things you should be doing before trackdays in the RA is add an oil cooler. It's cheap insurance from engine damage and will help keep coolant temps lower as well.
230kw/430nm @ 24psi on E85
12.191 @ 108.81mph - Fastest stock turbo ralliart in Australia
www.facebook.com/BoostinJuiceTuningSydney
www.clubcj.net/viewtopic.php?p=369141#369141
Return to “2008+ Turbo Performance”
