WTB : Evo X intercooler with piping
Eazay
Postby Eazay » Mon Mar 23, 2015 2:11 pm
Hi guys, thinking of upgrading to the evo intercooler set up. Can't seem to find any currently for sale. Would prefer NSW
Only thing i've found are aftermarket units -
http://www.gumtree.com.au/s-ad/coopers- ... 1073300263
is this a viable option if all else fails ?
rustybucket
Postby rustybucket » Tue Mar 24, 2015 2:15 pm
I have been wondering about that exact set.
Anyone with any experience with these?
Also available on ebay
http://www.ebay.com.au/itm/KLS-turbo-In ... 541c26f0a6
el3ment
Postby el3ment » Tue Mar 24, 2015 5:13 pm
I bet made in china crap??
But good luck anyway. I wouldn't touch it
zedd82
Postby zedd82 » Wed Mar 25, 2015 6:28 am
Check with Alan from AK Racing, he had a few a couple of months ago and might still have some.
Eazay
Postby Eazay » Wed Mar 25, 2015 7:33 am
Cheers guys, how did you find the fmic install? did you keep the stock lower pipe?
r00tc4u53
Postby r00tc4u53 » Wed Mar 25, 2015 2:41 pm
PM sent in regards to available cooler due to aborted RA mods
megatron
Postby megatron » Thu Mar 26, 2015 10:12 am
i have 1 stock Evo X cooler left with stock pipes.
as for china IC, NOT saying the above is the case. but we did alot of testing on a few and found they performed less that stock evo X once heat soaked. where as high end coolers like ultimate racing, plazaman, ETS, AMS etc work better. in both temps and pressure drop.
megatron
most things are cheaper for a reason
the sam
Postby the sam » Thu Mar 26, 2015 8:10 pm
I've had great results from the cheaper Chinese (KLS) coolers for anything under about 250 kw. Above about 27-28psi yes they do tend to perform worse than the more expensive brands. But for a street car with, say 220wkw, they perform flawlessly with minimal heat soak. If you are tracking hard, I would lean towards something like a Plazmaman cooler, but if you are not beating on it hard it will make a minimal difference.
230kw/430nm @ 24psi on E85
12.191 @ 108.81mph - Fastest stock turbo ralliart in Australia
www.facebook.com/BoostinJuiceTuningSydney
www.clubcj.net/viewtopic.php?p=369141#369141
Return to “Buying & Trading”
Users browsing this forum: Google [Bot] and 14 guests
