Starter motor help ASAP
Need help can't get starter motor out from the space it's in. Got the two bolts out and the ground off but just can't shimmy it out. It's a lancer cj activ 2012, is there something I should take out to be able access the starter motor easier? And would it be easier to access from the top or the bottom? Thanks
If you do a quick search on here there is a free workshop manual available either for download or browse.
Your removal\installation instructions can be found on
16. Engine Electrical -> Starting System -> Starter Motor Assembly
If you have removed all the bolts and the terminal wires then it should come off with a light tap.
Re: Starter motor help ASAP
Sorry for bringing up an old topic but I can't get the starter motor out either. And the link to the workshop manual doesn't seem to work anymore! Please help
Workshop manual is there -http://www.clubcj.net/workshop/SEARCH/2008/index_M1.htm
Users browsing this forum: No registered users and 48 guests
