Purpose:
Ever ...
... wanted the answer to something but couldn't be bothered to search for an existing threaded answer?
What to do?:
Post your questions here and some helpful soul will point you in the right direction... .
Graham wrote:I'll ask a few random questions to get it going then
How would LED brake lights go brighter when you use the brake?
Would it change the output from 9v to 12v? Same with the normal filament bulbs, but I already know they have two filaments inside of them.
It uses a little circuit inside the bulb to drop the voltage across the circuit when in TAIL mode. When STOP is needed, it bypasses this circuit.
Where is the sensor for auto dusk sensing headlamps? is it the same as windscreen wipers?
Yes, the sensor for both is integrated into the one unit. Located in that big black thingo behind the centre rear view mirror
Why are there dots at the top center of the windscreen? Is this where there is certain materials that are not in that spot which are in the rest of the glass? (sounds stupid, but a friend told me it and im not sure of it)
Don't understand what you mean...
What are the two circle hole thingo's in the front/rear bumper for?
These are the pop-out cover for the tow hook thread. There is a big screw-in tow hook located in the tool bag with the spare wheel.
What is the easiest way to modify MMCS to be able to use it whilst the car is in motion. Not for me to watch movies or anything stupid like that, but if I need to dial a friend with me on a cruise it is alot more convenient. and using maps, or getting passenger to enter map information.
There is no mod currently for the Australian MMCS. Go aftermarket if you want that functionality.
Why does the CJ Lancer not have a bonnet that stays up by itself? (I think I've seen this somewhere before, but can't remember where.)
Saves cost and complexity. For the amount of times you need to open the bonnet, is it really necessary, seriously?
that's all I can really think of for now :p
You're welcome.
Users browsing this forum: Bing [Bot] and 6 guests
