Front oxygen sensor?
- lantourismo
Has anyone changed their front oxygen sensor, got the feeling mine is due to be replaced. How much work was it, OEM vs aftermarket etc?
- lantourismo
lol, no mate, i`ve never heard of it being done before, i`m not even sure what the front sensor does in relation to engine management.
it IS only a narrowband sensor though so it only reads high or low, not increments inbetween.
as to why your running very rich?, i have no idea.
maybe u should take your foot off the throttle? or maybe its the excessive heat in WA evaporating your fuel?
- lantourismo
Even when I'm gentle it still uses more then typical, after reading what ppl on here mention about their own fuel use. My average sits around 10-12 most of the journey, doesn't sound right.
So I'm trying to trouble shoot the excessive use, I was under the impression a worn oxygen sensor would give the engine false readings so it would try to compensate by burning extra fuel?
- lantourismo
- lantourismo
There are many things that could cause your car to run rich/use too much fuel. O2 sensors arent cheap for genuine, and would run you up at least a few hundred bucks for an aftermarket one based on other ones ive replaced. If its royally "screwed", scanning for codes will bring it up and then i would no question replace it, but it could simply be dirty and need a clean off assuming it is the O2 sensor, however i do advise taking it into a licensed mechanic to do so, as they are very sensitive and sometimes even handling them in the wrong fashion can "screw" them. O2 sensors however typically are good for 2-250km in todays cars with very low premature failure %.
Take it into a good mechanic, tell him to check it out and see what they come out with.
- lancerdarryl
ditch the ethanol from the fuel and you will get better kms.
I'm not sure exactly where but there was a law put in place that all fuels need to be 10% Ethanol by a certain year but i think that was for the eastern states
Also some 95 and 98 are just 91RON boosted with ethanol. giving it that higher octane rating.
