Your newest CJ enthusiast.
lawrencepartington
Postby lawrencepartington » Sat Oct 11, 2014 10:30 am
Hey everyone,
I have owned this lancer for about three weeks!
2008 LANCER CJ ES
Bought for $7,500
Stock standard at 119,000Kms
4cyl Manual 2.0L 113kW
Alloy wheels with month old tyres.
Drives fantastically compared to my very first car (temp).
When i need the power all i need to do is leave it in the lower gears, so its also great to control economically under 2000's revs :)
So far i have currently:
¬ Plasti Dip'd grill and emblems
¬ Replaced cabin and boot lights with Bright Blue LED's
http://www.ebay.com.au/itm/180965122419?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
¬ Installed Fusion CS-AT1100 Subwoofer (shakes the shit out of the car)
http://www.ebay.com.au/itm/271280235017?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
¬ Replaced gear shift nob
http://www.ebay.com.au/itm/311008211208?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
D
Postby D » Sat Oct 11, 2014 10:35 am
(WTTC)
Always good to have another sa member, hope to see you on a cruise some time
ROTM WINNER SEPT 2014
mmjjee
Postby mmjjee » Sat Oct 11, 2014 10:45 am
Welcome buddy! Car looks nice!
How are the interior blue lights? Got the exact same coming in next week
Postby VRX_08 » Sat Oct 11, 2014 11:02 am
Welcome, nice to see you joined up after a weird discussion through Ebay regarding a item you had for sale! :D
belle_tb_ES
Postby belle_tb_ES » Sat Oct 11, 2014 11:37 am
Welcome!
lawrencepartington
Postby lawrencepartington » Sat Oct 11, 2014 1:18 pm
mmjjee wrote:Welcome buddy! Car looks nice! How are the interior blue lights? Got the exact same coming in next week
They look great man, gives your car a cool little touch.
In the packet i got 3 LED's for $20, so i decided to solder them in series to get a brighter look, worked great! Trial and error i busted two 15amp fuses doing this :oops:. The fuse is located behind the glove box :)
The same type of LED fits the boot light, so maybe only use two for the cabin light as i had to order a 4th one.
:D
Last edited by lawrencepartington on Sat Oct 11, 2014 2:06 pm, edited 1 time in total.
kay christensen
Postby kay christensen » Sat Oct 11, 2014 1:22 pm
welcome it is good to see another SA member :D :)
(cj-red)
Postby Mystique » Sat Oct 11, 2014 2:50 pm
Welcome! :)
mmjjee
Postby mmjjee » Sat Oct 11, 2014 3:05 pm
lawrencepartington wrote:[quote:b07505058b=mmjjee]Welcome buddy! Car looks nice! How are the interior blue lights? Got the exact same coming in next week[/quote:b07505058b] They look great man, gives your car a cool little touch. In the packet i got 3 LEDs for $20, so i decided to solder them in series to get a brighter look, worked great! Trial and error i busted two 15amp fuses doing this :oops:. The fuse is located behind the glove box :) The same type of LED fits the boot light, so maybe only use two for the cabin light as i had to order a 4th one. :D
They look sick dude! So you just kept the map lights stock?
Craig
Postby Craig » Sat Oct 11, 2014 3:50 pm
Welcome :)
Seffy
Postby Seffy » Sat Oct 11, 2014 7:40 pm
Welcome!
Zaphod
Postby Zaphod » Sat Oct 11, 2014 7:56 pm
:) 8) :welcome: :wink: :P
lawrencepartington
Postby lawrencepartington » Sat Oct 11, 2014 8:01 pm
D wrote:(WTTC) Always good to have another sa member, hope to see you on a cruise some time
VRX_08 wrote:Welcome, nice to see you joined up after a weird discussion through Ebay regarding a item you had for sale! :D
belle_tb_ES wrote:Welcome!
kay christensen wrote:welcome it is good to see another SA member :D :)
Mystique wrote:Welcome! :)
mmjjee wrote:[quote:cfa00eb74f=lawrencepartington][quote:b07505058b=mmjjee]Welcome buddy! Car looks nice! How are the interior blue lights? Got the exact same coming in next week[/quote:b07505058b] They look great man, gives your car a cool little touch. In the packet i got 3 LEDs for $20, so i decided to solder them in series to get a brighter look, worked great! Trial and error i busted two 15amp fuses doing this :oops:. The fuse is located behind the glove box :) The same type of LED fits the boot light, so maybe only use two for the cabin light as i had to order a 4th one. :D[/quote:cfa00eb74f] They look sick dude! So you just kept the map lights stock?
Hoges wrote:Nice job on the festoon lamps! For the boot, buy a 1.2m led strip and use spade connectors to plug into the boot light socket. Lights up the entire boot
Craig wrote:Welcome :)
Seffy wrote:Welcome!
Zaphod wrote::) 8) :welcome: :wink: :P
A big thanks to everyone! You're all so nice here :D
lawrencepartington
Postby lawrencepartington » Sat Oct 11, 2014 8:08 pm
mmjjee wrote: They look sick dude! So you just kept the map lights stock?
I had no idea it was called the map lights haha! The shape of the LED's are literally just a tiny bit wider than the normal stock light, fantastic fit if you just decide to put one in.
For my installation the positive connection was slightly tarnished, so i noted which side was which (+/-). I soldered them all in series, (you can tell which way they go by just holding it to the two ends). Then i soldered two external wires which hooked into the the slot and pushed the plastic cover back into place. unhook your negative battery terminal when trying to hook them in as you will most likely have to bed the wires into place! BOOM, BLUE BOLT INTERIOR (cj-blue) *nod*
Users browsing this forum: No registered users and 121 guests
