WTB: LX/VRX trim parts - All sourced - Thanks guys! :-)
Zaphod
Postby Zaphod » Fri Aug 15, 2014 10:30 pm
Hi All!
I'm chasing some bits & pieces from a VRX or LX:
Firstly I'm after these bits...
Which is the upper centre console with lids and manual gearshift surround, and also the climate controls & surround.
I need another one of these too if one comes up:
Also looking for a set of blank foglight panels from a Sports or RA:
Oh, and a GPS unit for a MMCS too!
Let me know!
Cheers :-D
lantourismo
Postby lantourismo » Fri Aug 15, 2014 11:04 pm
For you or someone else?
Zaphod
Postby Zaphod » Sat Aug 16, 2014 6:06 am
Well, I can't use two fascias in the one car... mind you, it could make for an interesting mod...!
For me; the other fascia turned up with a couple of broken clips and it doesn't sit down quite right, and I want to upgrade the interior (eventually would like the black dash & door trims, same as last time.
lantourismo
Postby lantourismo » Sat Aug 16, 2014 7:28 am
No one in Sydney can help? Curios you want RA style fog light surrounds?
Zaphod
Postby Zaphod » Sat Aug 16, 2014 7:54 am
Really Akram/ Do I need interrogating every time I post a WTB...?
Everything's for me.
Postby sleeper » Sat Aug 16, 2014 8:01 am
he probably asked cos a RA fog surround is a different shape to a NA fog surround
lantourismo
Postby lantourismo » Sat Aug 16, 2014 9:04 am
Zaphod wrote:Really Akram/ Do I need interrogating every time I post a WTB...? Everythings for me.
Well It's called showing interest :) and those fog surrounds are for a RA bumper normally.
sleeper wrote:he probably asked cos a RA fog surround is a different shape to a NA fog surround
Naturally it is, but he has an NA bumper
Zaphod
Postby Zaphod » Sat Aug 16, 2014 12:04 pm
@ Akram - fair enough, didn't mean it that way, so accept my apologies (it was a bit too early and I have no coffee at home - it's not a good way to be...)
@Sleeper - You may be on to something there... :-)
lantourismo
Postby lantourismo » Sat Aug 16, 2014 12:17 pm
Zaphod wrote:@ Akram - fair enough, didnt mean it that way, so accept my apologies (it was a bit too early and I have no coffee at home - its not a good way to be...) @Sleeper - You may be on to something there... :-)
Accepted, but I think you should add coffee to your wanted list :)
Hmm Martin I think I know what your up to, will wait an see.
Postby sleeper » Sat Aug 16, 2014 12:20 pm
oh nooo, he`s buying a RA front end, heh.
Zaphod
Postby Zaphod » Sat Aug 16, 2014 12:31 pm
Muad-Dib... Muad-Dib... Muad-Dib... Muad-Dib... Muad-Dib...
Postby sleeper » Sat Aug 16, 2014 1:09 pm
the sleeper has awakened
Seffy
Postby Seffy » Sat Aug 16, 2014 1:11 pm
IIRC (If I recall), I read on here somewhere where there was someone here that made the climate control actually work in Lancers that don't come with it.
The climate control knobs don't give it by default if you put it into one without CC, but there are a couple of probes/sensors that you can put in their respective places to enable it.
Just a bit of info for ya. :) If you can somehow source those parts to make the CC work, you should snag them.
lantourismo
Postby lantourismo » Sat Aug 16, 2014 1:15 pm
Seffy wrote:IIRC (If I recall), I read on here somewhere where there was someone here that made the climate control actually work in Lancers that dont come with it. The climate control knobs dont give it by default if you put it into one without CC, but there are a couple of probes/sensors that you can put in their respective places to enable it. Just a bit of info for ya. :) If you can somehow source those parts to make the CC work, you should snag them.
That's correct, a temp sensor and tube near the steering column, and a photo sensor in the dash near the glass, I did both and it does run te climate controls better.
Zaphod
Postby Zaphod » Sat Aug 16, 2014 1:56 pm
Ta Joseff - Akram got onto that a while back - it works 'ok' with just the cabin air sensor, better with both as we have this thing in Qld. called sun...!
Return to “Buying & Trading”
