is this fluid ok for a ralliart diff?
R4LLI4RT
Postby R4LLI4RT » Tue Aug 05, 2014 10:42 am
Its sae90 which I think is the same as the oem stuff
3Inch Custom Cat Back Exhaust
Home Brand Alloy UICP
K&N Panel Filter Replacement
DBA Extreme Pads
Turbosmart Dual Port BOV
Tein S Tech Springs
BZC-45S
Postby BZC-45S » Wed Aug 06, 2014 12:12 am
Yes, extremely well suited. 4 litres will last you eight changes (assuming you're doing rear diff only) which is 240,000kms.
R4LLI4RT
Postby R4LLI4RT » Wed Aug 06, 2014 10:50 am
excellent!
so it only takes 500ml per service???
DBA Extreme Pads
Tein S Tech Springs
BZC-45S
Postby BZC-45S » Wed Aug 06, 2014 6:34 pm
Transfer case req about a litre. Rear diff probably 600mls or so, I cant remember but it is quite small volume.
