LEDS Number plate lights TO BIG ?????
gman90
Postby gman90 » Sat Apr 12, 2014 5:33 pm
Hi All I brought a pair of super bright led number plate lights but they are to big to put the dust cover over them what could i do to fix the gap between the number plate base and the dust cover any one had this problem ?????/
Thanks gazza :?:
D
Postby D » Sat Apr 12, 2014 5:38 pm
gman90 wrote:Hi All I brought a pair of super bright led number plate lights but they are to big to put the dust cover over them what could i do to fix the gap between the number plate base and the dust cover any one had this problem ?????/ Thanks gazza :?:
I did the same thing, I ended up returning them and getting slightly smaller ones, the only thing I thought of was to disassemble the plug and do it that way but then the back is unsealed unless you get that double sided foam stuff and use that to bridge the gap
ROTM WINNER SEPT 2014
gman90
Postby gman90 » Sat Apr 12, 2014 6:25 pm
Hi yes I was thinking of the same thing the double sided tape? ????? Any other ifesd people
gman90
Postby gman90 » Sat Apr 12, 2014 6:26 pm
Hi yes I was thinking of the same thing the double sided tape? ????? Any other idea"s people Gazza
