How do you remove the trim under the steering wheel?
Stealthmatt
Postby Stealthmatt » Tue Mar 11, 2014 8:12 am
How does one remove the trim under the steering wheel column. There is an airbag their.
I removed the screws in it and the foot well cover, but still seems hard to remove?
I am trying to be cautious because I don't want deploy the airbag.
lantourismo
Postby lantourismo » Tue Mar 11, 2014 8:19 am
There is also three plastic clips down the bottom use a screw driver to pry them up and pull out caution is good just apply firm pressure along the edges of the trim. With the airbag just apply gentle pressure on it when removing trim around it. It won't come out with it as it's attached separately
Stealthmatt
Postby Stealthmatt » Tue Mar 11, 2014 11:01 am
Do I need to remove any trim above like the piano plastic bar? or the left foot side cover (near the clutch).
Also will the airbag cover come out or will that stay in?
Do i pull the it downwards or upwards the whole piece of plastic?
rokpapaziz
Postby rokpapaziz » Tue Mar 11, 2014 11:17 am
Stealthmatt wrote:Do I need to remove any trim above like the piano plastic bar? or the left foot side cover (near the clutch).
Nope
Stealthmatt wrote: Also will the airbag cover come out or will that stay in?
It will stay in, doesn't move.
Stealthmatt wrote: Do i pull the it downwards or upwards the whole piece of plastic?
pull the bottom out/up, comes out easy.
Be careful of the traction control switch, once the panel is removed you will need to disconnect the wires from behind. Don't yank the panel off too hard!
R4LLI4RT
Postby R4LLI4RT » Tue Mar 11, 2014 11:21 am
just disconnect the battery if ur worried about the airbag.
takes a bit of the bag to deploy
3Inch Custom Cat Back Exhaust
Home Brand Alloy UICP
K&N Panel Filter Replacement
DBA Extreme Pads
Turbosmart Dual Port BOV
Tein S Tech Springs
lantourismo
Postby lantourismo » Tue Mar 11, 2014 12:05 pm
It's like Lego as someone once told me, just clips and screws. The airbag is there but won't deploy without a considerable impact
Damir
Postby Damir » Tue Mar 11, 2014 7:38 pm
I've removed this many times
it won't come off completely unless you remove the main trim piece under the head unit but it will move out of the way for you to access the switches
Remove the 2 screws down bottom and the plastic clips down bottom
from there carefully pull it out from the bottom towards you
to put it back in make sure you get the clips where the airbag sits flush
quite an easy removal
Zaphod
Postby Zaphod » Tue Mar 11, 2014 8:09 pm
lantourismo wrote:Its like Lego as someone once told me, just clips and screws. The airbag is there but wont deploy without a considerable impact
I once witnessed a BF Falcon turn across the path of an oncoming ute - I estimate the combined collision would have been 80Km/h - the front of the Falcon was gone completely - no airbags deployed in the Falcon because the crumple zone reduced the impact sufficiently.
The ute didn't fare too badly, it was one of those 'indestructible' ones.
You can't set of an airbag just by punching it, disconnect the battery and you'll be fine...
Stealthmatt
Postby Stealthmatt » Tue Mar 11, 2014 9:49 pm
Well I got it out with ease... I didn't need to remove the main trim at all.
I just need to force it out a bit more and came out pretty easily...
putting it back on was another thing, had to line up the clips with the air bag surround and i was trying to put the under carpet inside rather than clip it from the front (took me a good 10 minutes to figure why the under carpet wasn't staying in place)
thanks everyone for your help :)
lantourismo
Postby lantourismo » Tue Mar 11, 2014 10:10 pm
Yeah the clips around the airbag can be fiddly to put back in properly
R4LLI4RT
Postby R4LLI4RT » Tue Mar 11, 2014 10:15 pm
good to see it all worked out!
DBA Extreme Pads
Tein S Tech Springs
Return to “Interior”
