DIY TC SST. Fluid change????
gman90
Postby gman90 » Sat Feb 15, 2014 1:20 pm
Hi I have read a lot about doing the SST fluid change but have read that after you drain the fluid you should start engine and let it idle for a minute or two with out putting new fluid in this is done to clear as much of the old fluid out before putting fresh oil in is this right or not ???? You then put Fresh oil in put foot on brake and go through all the gears Or would you bring all 4 wheels off the ground and allow wheels to spin through reverse neutral forward and park just need to get it right the first time. Thanks. Gary
gman90
Postby gman90 » Sat Feb 15, 2014 1:22 pm
Plus you put back the same amount of fluid that you have drained?????
gman90
gman90
