Ok so i just got the car back from the panel beater after putting in some new lights and repairing some panel damage from a hit and run the other day. The car was running completely normal before i took her into the shop, and she was running fine for the 15 minute drive home when i picked her up on friday. The next time i started the car, the check engine light was on and the car was running very sluggish. She was idling at 600rpm as normal and the car sounded fine, but the acceleration has plummeted and is very slow to get speed now. Also after 20 minutes of driving, it'll say my traction control is off, and that a service is required (I got the car serviced 2 months ago!). If i turn the car off and back on, those alerts will go away but reappear after another 20 or so minutes of driving.
I have absolutely no idea what's wrong, does anyone have suggestions for me to try or check out? Thanks in advance guys!
Looking for advice, please help!
Jason-ES wrote:What lights were fitted? Sounds like ECU is picking up low amperage use of a light circuit often found when led lights are fitted.
I got fit a pair of head lights and tail lights from mars performance. The new lights could explain the check engine light but i can't see how it would be the cause of the low acceleration
- lantourismo
Jason-ES wrote:Fit the appropriate resistors and everything should be okay. I would refit stock tail and reset the ecu to see if that fixes the problem. I thought all aftermarket tail lights were fitted with resistors. Good luck.
Took it to Tynans yesterday and they changed the brake switch, that didn't work. I have to take it to an auto electrician to fit the resistors so the computer reads the right voltage again.
I was told that when the computer detects a problem, it "assumes the worst" and limits power to the engine until the problem is fixed, so it's relieving at least that the car is still mechanically sound
