Tiff's adventure with Plasti Dip!
Postby Mystique » Sat Nov 30, 2013 2:25 pm
I had a small adventure today with Plasti Dip.. Oh Plasti Dip.. You are simply fantastic... except I screwed it up :P Was happy with the finished product and then I didn't like it so i pulled it off all xD Decided it's going to be easier to get it vinyl wrapped :S and I didn't like the chrome with it either ;S
But...
Without number plate! Am very hesitant to put it back on :(
All Taped up :P haha.. I went overboard but I wanted to be safe then sorry....
First coat:
After a few more coats, it was the finished product after pulling the Newspaper and tape off... and well.... I ended up pulling it all off, I just need to get a knife and scrape the rest off >_< The masking I did was a lil uhh :S Horrible because it started pulling the rest of the plasti dip off with it... and this is how it ended up :P
and after pulling the plasti dip off, the only thing it really stuck to was the white spot that's on my front bumper :S I guess it looks like she has a beauty spot or something lol.... But in saying that, I think I'm going to just get it vinyl wrapped and the chrome removed :S I didn't like how it turned out xD it looked like my car had a mustache... :S
vermilioN
Postby vermilioN » Sat Nov 30, 2013 2:30 pm
dat beauty spot.
Postby Mystique » Sat Nov 30, 2013 2:31 pm
Ikr? >_<
Definitely getting it vinyl wrapped... or may give it another go next weekend... but I'm not feeling that spontaneous now xD
Postby sleeper » Sat Nov 30, 2013 2:49 pm
strange tiff, i dont know what went wrong there, u did everything right :(
maybe the grille was waxed or something, just guessing.
normally its a piece of cake
Postby Metalstrix » Sat Nov 30, 2013 2:58 pm
it looked alright! lol
D
Postby D » Sat Nov 30, 2013 3:21 pm
Did you let it dry fully?, because that may be your issue, if you peel the masking off straight after you spray the last coat (whilst it is still wet), you will get nice smooth edges and the dip will stay where as if you peel it once dry it will take the rest with it as it has already bonded together thus the whole strip will come off, hope this helps
ROTM WINNER SEPT 2014
Postby Mystique » Sat Nov 30, 2013 3:32 pm
I took it off after the did the last coat :)
Postby Mystique » Sat Nov 30, 2013 3:33 pm
I'm going to leave it :P and try again next weekend >_< might've been because I used the xpack car wash stuff when I washed the front bumper before doing it >____<
:S
Luke
Postby Luke » Sat Nov 30, 2013 9:45 pm
I was following the whole shabang on Instagram, thank's Tiff ahaha
It may look better RA style ;) with the chrome above and below blacked out and some chrome 'tape' stuff around it?
http://www.ebay.com.au/itm/10mm-Chrome- ... 856&_uhb=1
it could either look reallllly bad or realllly good aha
just a thought :)
Frosty
Postby Frosty » Sat Nov 30, 2013 10:01 pm
The trick is to remove the tape after each coat while the plasti-dip is still wet and re-apply new tape (in the exact same location) for the next coat. Otherwise you will run into the problem you experienced >.<
Also, wash the surface with wax and grease remover before spraying, some car washes include a wax which will stop the plasti-dip from sticking.
Happy dipping! :)
2.0L - K&N Typhoon SRI - High-Flow Exhaust System - Merlinised
Postby Mystique » Sun Dec 01, 2013 12:20 am
Haha sorry Luke for all the posts on Instagram ;) thought I'd keep people updated haha! :P
Oooh! Thanks for the tip :3 shall keep it in mind when I try again! Am thinking that the chrome needs to go :3 although I do like it with how it is normally >_< but gah! XD
Kal777
Postby Kal777 » Sun Dec 01, 2013 10:37 am
Wax and grease remover will get any overspray off the car and neaten up the edges.
RallyNut
Postby RallyNut » Sun Dec 01, 2013 11:57 am
What i found with plastic dip is that you dont want it to dry up fully between each spray i only waited like 2-3min between each spray.
it worked for me...
pepople told me to do the tape after each spray as well, im sure it should go well, but im just dont have the patience for that.. ;P
maybe give it a shot.
Postby Mystique » Sun Dec 01, 2013 12:11 pm
I left it 10-15 between each coat :P
Will keep that in mind next time though >_<
Am definitely thankful for all the tips guys! :) Especially the ClubCJ Vic guys on Facebook :)
Especially Damir who's been following me on Instagram and giving out advice as well :P I really appreciate it everyone!! :)
I'm definitely going to be removing the chrome and spraying that as well :P I'm going to have to do a search on here how to remove the front bumper though haha :P Although for a first timer, I am proud of how it turned out :P It could've been alot worse :P haha, I was honestly scared of doing it :P Because I've never ever done anything like this before xD but, anyway :P
JoelT
Postby JoelT » Sun Dec 01, 2013 10:29 pm
if you dont want the chrome why dont you plastidip the whole front bumper including the chrome?
surely that would be easier than taking the chrome strip off etc
Users browsing this forum: No registered users and 97 guests
