exploded turbo removal pic
Postby sleeper » Sat Nov 30, 2013 12:01 pm
does anyone know where i got this from?
i cant find it again and for some reason the bottom is missing :(
thanks
vermilioN
Postby vermilioN » Sat Nov 30, 2013 12:07 pm
When ever I go to the spare parts place at mitsubishi they give me papers just like that so I can show them what im talking about.. Thats your best bet imo. For the turo swap I presume ;)
Postby sleeper » Sat Nov 30, 2013 12:10 pm
yeah, turbo swap :)
thanks mitch, thats prolly where i got it from, no idea why i cut the bottom off :(
its handy for part ID too
vermilioN
Postby vermilioN » Sat Nov 30, 2013 12:47 pm
No problem, you probably know about this but I used this.
http://www.atpturbo.com/root/help/pdf/i ... ctions.pdf
it was pretty helpful some stuff is different though.. I hope everything goes smoothly for you, its not THAT hard to do but you will reach points where the bolts wont come out! I damaged the oil line thread when installing it and nearly needed a new engine!! so be careful.
Postby sleeper » Sat Nov 30, 2013 12:50 pm
got that one, thanks.
thanks for the thread tip.
i also found a how to on the "bolt from hell"
i imagine its not that hard but for me research is half the fun :)
Postby sleeper » Sat Nov 30, 2013 12:52 pm
maybe we should correlate all this info/links on a thread *shrug*
vermilioN
Postby vermilioN » Sat Nov 30, 2013 1:01 pm
Sounds like a good idea, and another thing with the oil line.. because its a hard line it can crack, you might need to bend it a bit into position so be careful. somebody did a turbo swap and cracked the line and nearly had a big fire with oil all over they're engine.
Postby sleeper » Sat Nov 30, 2013 1:03 pm
have u seen this one
http://goo.gl/5E7wkW
vermilioN
Postby vermilioN » Sat Nov 30, 2013 1:56 pm
Yeah ive seen that.
