Hey guys,
Long story story, i live in an apartment building, with many cars coming and going, the ralliarts alarm (pretty sure its just the stock alarm) is constantly going off.
It's way too sensitive, and goes off if a loud car drives past and It's pretty annoying.
Is there any way i can change the sensitivity of the alarm?
Cheers.
Alarm Sensitivity - can it be changed?
Something else you could try, look in the User Manual under Alarm Operation and you can turn off the internal motion sensor by (I think) holding the wiper/washer stalk in for 3 seconds after you turn the car off. This stops the noise vibrations setting off the alarm and is also good on a hot day if you leave your windows cracked open. It automatically resets next time you start and Stop the car. The alarm will still go off if anyone tries to break-in to the car
_________________________
Yep, Another Red RA Hatchback
paradox_108
- Lancer Learner
In the original kit installation (with an on/off switch mounted in the glovebox) there are three sensors mounted in the console between the front seats (glass break; tilt and shock). The shock is the rounded blob nearest the drivers seat and has an adjusting screw in the side. Rotate anticlockwise to reduce sensitivity (which was required on installation).
Cheers, Doug
Cheers, Doug
