Hi guys, i cant decide which brake pads are better! Its for a Lancer with a 4B11T motor in it. Brakes have been upgraded to the Ralliart ones.
Now the pads im not too sure whats better ? I need pads to hold atleast 180kws of power and hill climbs!
Theres the BREMBO pads, but i cant find anything good on them ? Are they just standard replacement ones or they an upgrade ?
http://cgi.ebay.com.au/ws/eBayISAPI.dll ... TQ:AU:1123
Or
Project Mu Spec B brake pads ? heard alot of good this about them. and thats around $200 for pads,
http://www.project-mu.com.au/en/products/pad_bspec.php
Thanks guys!
Which Brake pads are better ?
FULL EVO X TURBO SETUP
BC RACING BR COILOVERS
Selecting good pads is a hard question to answer because it depends on vehicle use. Great pads for track won't be good for suburban streets because they don't brake well when cold. And good pads that work well when cold can't take the heat of track use. Also some pads can be very hard on discs which can become very expensive.
Sorry Daniel I can not agree with you on EBC pads. They are well marketed but over priced and not the greatest pads.
I found Elig pads very good and not expensive compared to other brands.
I used QFM pads on my Chaser and bought a set to put on the Ralliart. Haven't tried them on the RA yet but they worked very well on the Chaser. Noticable improvement in stopping. Cheap too, less than $100 for fronts. I think they are made in Aus. Bit dusty though.
scott_drake
When i had my evo
EBC- GREEN stuff....Rubbish, I got my discs to glow, stopping was not good
EBC - RED stuff..And OK pad, needs alot of heat to get them to stop nice, but brake fade comes very quick on these, noisy when cold and not to bad on dust
EBC- YELLOW stuff...Only for track
Bendix Ulitmates- Chew out rotors and RUBBISH for a performance pad vs $$$
Project Mu- Chew out rotors, and require alot of heat to get them to work good, Track pad only
Ferodo DS2500- Excellent Brake Pad all round, Work excellent when cold or hot and take a while to get brake fade....Dusty as hell but damn worth every dollar, but do not sit on the pads after they get hot otherwise you will crack/warp your rotors
Ferodo DS3000- Only for track
Hawk- These make the ferodos feel like bendix general ct pads, they have so much force when stopping its enough to give you whiplash and brake your neck....your abs will be kicking in every time you stomp on these pads, Only for a track car with the brake booster and abs GONE!
Go the Ferodo ds2500 you will be more than happy after bedding in
So choose your poison carefully
scott_drake
WOW thanks guys!
umm yeah im just looking haha
I forgot to mention, that i will be using RDA slotted and dimpled rotors.
Brembo pads is maybe.... No ones knows anything about them?
Project Mu, i heard alot of good things about the spec B not the crazy one thats for track hahah
All the track pads i know they takes ages to warm up for daily driving and hills.
and yeah Red stuff i heard good stuff too! But yeah too much to choose from LOL
There is also remsa, I haven't used them but have been recommended to me. I've currently got ebc redstuff stop ok when cold, get better when they warm up but I have cooked them a few times, might try something else next time to see how they compare. They have been on for just over a year and it's time to replace them.
enkei sc 22 wheels
enkei sc 22 wheels
scott_drake
denzza wrote:WOW thanks guys! umm yeah im just looking haha I forgot to mention, that i will be using RDA slotted and dimpled rotors. Brembo pads is maybe.... No ones knows anything about them? Project Mu, i heard alot of good things about the spec B not the crazy one thats for track hahah All the track pads i know they takes ages to warm up for daily driving and hills. and yeah Red stuff i heard good stuff too! But yeah too much to choose from LOL
DENIS...DONT USE RDA rotors on your car once that motor goes in
I have CRACKED rda rotors on my previous lancer like yours a few years ago....and let me say it was a close call
Brembo pads from memory are Ferodo Ds2500
I have rda slotted on at the moment and seem to get hot and turn blue quick. Going to try dba t3 slotted next time. Still deciding on pads.
enkei sc 22 wheels
enkei sc 22 wheels
So those brembo pads are ok to get?
Hmmm, great!!!
Now I need to look at rotors
What about rda gold? Or something from the project mu range?
Hmmm, great!!!
scott_drake
Anybody used intima sr pads are heard anything bout them
http://www.ebay.com.au/itm/261295265548 ... 1423.l2649
These ones
These ones
enkei sc 22 wheels
enkei sc 22 wheels
