Advice/opinion on LED strip for DRL
ashleymorris
Postby ashleymorris » Fri Sep 20, 2013 3:19 pm
I'm a little bit broke at the moment so I'm trying to cut costs temporarily :P
Until I have the money to get the headlights I want I was thinking of just buying some LED strips from Autobarn as they have some that are only $16 per 1m.
Just wondering if anyone else has done this instead of replacing the whole headlight and if you have any advice about whether it's worth it or not??
These are the ones
markalishous
Postby markalishous » Fri Sep 20, 2013 5:02 pm
I have put LED strips under my headlights but i got mine from ebay for roughly $10 or something i cant remember exactly. Anyways the ones that you have there will probably not work as you need to get side emitting LED lights as otherwise they will just shine down into your front bar which wont do much and probably not look to great. if you are interested i will find the link to an ebay listing for the kind of thing you are after and i will upload a picture of how it could look.
Cheers,
Mark.
LuLu
Postby LuLu » Fri Sep 20, 2013 9:36 pm
Chris (Cam000) has some under his lights I believe that look decent, try shooting him a pm? :)
Postby Metalstrix » Fri Sep 20, 2013 10:45 pm
If you go to my signature and click the link, there's a few suggestions in there for you Ash.
ashleymorris
Postby ashleymorris » Sat Sep 21, 2013 3:13 pm
Awesome, I'll have a look when I can thanks guys :)
I'm just worried about not being able to easily hook them up, but one of my mums friends is an auto electrician so I guess no matter what I get he'll be able to figure out a way to wire them!
Do you have headlight protectors on over your lights, Mark?
Damir
Postby Damir » Sat Sep 21, 2013 5:07 pm
look at jess' car
forum name is fizzlefuzzle and her build thread is a pink black lancer
she has done this mod too
Dire
Postby Dire » Sat Sep 21, 2013 5:53 pm
craigeth
Postby craigeth » Sun Sep 22, 2013 9:59 am
I did this with lights from oznium. It was easy to splice into the parkers and run down to where I mounted them, which was just above the fog lights. However they never stuck properly and some of the LEDs died after only a couple of month. So I took them out.
If you want proper DRLs you're better off going for whole new headlights in my opinion.
http://www.ebay.com.au/itm/181172844414?redirect=mobile
www.twentythreeframes.com
Fizzlefuzzle
Postby Fizzlefuzzle » Sun Sep 22, 2013 10:12 am
Hi there! Thanks Damir!
Yes I have these on my car and love them, they are fairly bright. Should be pics on my build thread. I also hooked them up so they tint off when my head lights turn on :)
ashleymorris
Postby ashleymorris » Sun Sep 22, 2013 10:49 am
Yeah that's what I want mine to do also, at least until I put some crystal vision bulbs in because they won't match until then haha
I'll go back through your thread when I have a computer. Where did you get yours from Jess?
Fizzlefuzzle
Postby Fizzlefuzzle » Sun Sep 22, 2013 10:57 am
Hmm super cheap I believe
Users browsing this forum: Majestic-12 [Bot] and 32 guests
