Adhesive bonnet protector/paint protector
LonePhantom
Postby LonePhantom » Fri May 22, 2009 10:10 am
Has anyone used this sort of stuff on their bonnet etc? I didn't want to stick on the usual ugly bonnet protectors, and have seen this stuff which looks pretty good.
http://www.altrex.com.au/shop.php?mode=item&i=676&p=
I bought some yesterday to put on over the weekend. the packaging doesn't contain any instructions, although I'm sure it's going to be somewhat like contacting school books! :lol: Just wondering if anyones used it, and if they had any tips on applying it.
Cheers! :)
dumb&
Postby dumb& » Fri May 22, 2009 11:04 am
I'd imagine it's just a vinyl...so plenty of soapy water to shift it around so it's positioned right and get rid of air bubbles.
Postby ofey » Fri May 22, 2009 11:56 am
Have to agree with daveee... .
criteek
Postby criteek » Fri May 22, 2009 12:02 pm
good idea, but i think it'll be a pain in the ass to do, cutting it, making it align, getting annoyed when it wont stay, getting more annoyed when u get bubbles, argh! lol
dumb&
Postby dumb& » Fri May 22, 2009 12:06 pm
I'd probably just do the edges (instant stone chip if you get even the smallest rock hitting) and front quarter, not the entire bonnet.
Bandit
Postby Bandit » Fri May 22, 2009 12:17 pm
I would also try and heat it a bit so it covers the rear vision mirrors. the oens on my car have been axed by stones for some reason - moreso than any other car I've had.
ClubCJ's first Sportback
LonePhantom
Postby LonePhantom » Fri May 22, 2009 12:34 pm
I wasn't going to do the whole bonnet, just the area that the Mitsubishi bonnet protector covers (the nose section).
Any left over stuff I was going to to the bottom of the front bar maybe, and the edges of the doors.
daveee wrote:I'd imagine it's just a vinyl...so plenty of soapy water to shift it around so it's positioned right and get rid of air bubbles.
Soapy water? How are you using that? I was going to clean and polish the car, make sure any contaminants are off the paint, and stick it on.
dumb&
Postby dumb& » Fri May 22, 2009 12:54 pm
Definitely do that beforehand. But by then having a layer of soapy water behind the vinyl it lets you position it without it sticking to the car, the water eventually evaporates and you're left with the vinyl in the perfect position, and no air bubbles.
Same method they use for window tint.
Just don't drive the car for a while after doing it (2-3 hours, and leave it in the sun).
LonePhantom
Postby LonePhantom » Fri May 22, 2009 1:09 pm
Ah cool, thanks. :)
What sort of soap. I'm guessing some sorts will leave residue underneath.
dumb&
Postby dumb& » Fri May 22, 2009 1:51 pm
Not sure exactly what they use...call up a sign writer and ask them what they use when vinyling stuff.
Josh_Emerton
Postby Josh_Emerton » Fri May 22, 2009 2:40 pm
I'd say it would cause faded sections if you only did half the bonnet?
Marsh
Postby Marsh » Fri May 22, 2009 3:15 pm
Use a few drops of dish washing liquid in a spray bottle of water. Thats what I used to do my vinyl and it worked perfectly
LonePhantom
Postby LonePhantom » Fri May 22, 2009 3:25 pm
Josh_Emerton wrote:I'd say it would cause faded sections if you only did half the bonnet?
Why do you think that would happen? It's completely clear, no tinting. Plus if the paint is looked after and has a clear coat that shouldn't happen.
Marsh wrote:Use a few drops of dish washing liquid in a spray bottle of water. Thats what I used to do my vinyl and it worked perfectly
Thanks for that, I was considering just using some hand soap or the dishwashing liquid, I'll probably go with that. :)
Josh_Emerton
Postby Josh_Emerton » Fri May 22, 2009 4:58 pm
I would just assume it would.
Sun fade doesnt really have any effect on the tinting of said adhesive, but more on the exposure. The fact that its covered changes the UV index regardless of tinting. Again, all assumption.
LonePhantom
Postby LonePhantom » Fri May 22, 2009 5:31 pm
Interesting thought. Mind you the same thing could happen from a conventional bonnet protector one would think.
