cracked the ayc bleed at home method finally!!!
scott_drake
Postby scott_drake » Thu Jul 11, 2013 4:23 pm
Finally figured out how to bleed the ayc without no damn scan tools and running to and from the dealer....
1. Suck fluid out of boot resiover
2. Take off drain bolts for ayc and acd
3. Let fluid run out
4. Put bolts back in
5. Fill up ayc and acd
6. Fill up resiover
7. Open t case bleeder valve,
8. get someone to turn the ignition to ON with your foot planted on the acceleration pedal but dont start it, repeart this step 5-10 times until no air bubbles come out...
9. Close t case bleeder valve
10. Open diff bleeder valve and repeat steps 8 and 9
11. Top up resiover
12. start car let it idle for 10-15mins, fluid MAY over flow through bottle, then suck out until its just above the max mark....and close your lid
Drive the car and check the fluid, and your set
Note when you start car it will go down to just below the min mark, then 5-10mins of idle will bring it just above the max mark....it will keep doing that no matter how many times you start the car...
Enjoy
scott_drake
Postby scott_drake » Fri Jul 12, 2013 9:57 am
500kms and no buzzing or error codes
