evo x oils, need advice
scott_drake
Postby scott_drake » Sun May 12, 2013 5:16 pm
As u know tue clutch on my car is gone so im buying part by part, i need advice on the oils,
Penrite ten tenths racing 10-40w engine oil, ( i have heard alot of people in the car comunity say its garbage)
Penrite racing brake fluid dot 4 (straight forward)
amsoil mtf 75-90w gl4 gearbox ( straight forward)
Amsoil sever gear 75-90w t case and rear diff ( does this require any lsd additive)
Ayc/acd fluids (what oils should i use)
Ive got the clutch kit, pads, spark plugs
What chromoly flywheel can i use?? And where to get
Waiting on: oils, slave cyclinder, oil feed line, oem gaskets, chronly flywheel, twm cable bushings, money for labour
scott_drake
Postby scott_drake » Wed May 15, 2013 12:39 pm
Wow 60+ views and not 1 bit of advice...jeez mabey i should hold off on posting very helpfull info regarding how to's and thoughts and reviews on products wich i know lots of you have been eyeing out...
scott_drake
Postby scott_drake » Wed May 15, 2013 12:41 pm
Dw please lock topic
megatron
Postby megatron » Wed May 15, 2013 1:06 pm
it might be because you haven't posted a clear question, or ppl have answered your question already in your other thread http://clubcj.net/viewtopic.php?t=13756
as for all other oil beside engine, everyone uses OEM
megatron
Postby megatron » Wed May 15, 2013 1:38 pm
answered in your other thread by RTR
http://clubcj.net/viewtopic.php?t=14205
scott_drake
Postby scott_drake » Mon May 20, 2013 9:03 pm
All sorted after alot of damn research
Elf full tech 5w-40
Amsoil gl4 gear box oil 75w-90
Amsoil svg oil 75w-90 t case n rear diff
Lsd additive for t case n rear diff oil
Motul rbf600 dot 4 brake fluid
Castrol atm fluid for ayc/acd
Castrol dex 3 power steering fluid
Genuine NISSAN gtr coolant (where going to try something different)
Ill let u guys know how those combination on fluids go
