EVOSCAN -ABS
All Brake Modifications.
Cammo00
EVOSCAN -ABS
Postby Cammo00 » Sun May 05, 2013 9:39 pm
can someone tell me does evoscan 2.9 talk to abs useing tractix 2.0 cable on a CJ 2007 My2008 Lancer VR.
And if so how?
Helping Lulu with abs light on his Vr Lancer
http://clubcj.net/viewtopic.php?t=14000&highlight=lulu
Love That Car. (cj-blue)
Postby himynameisdaniel » Mon May 06, 2013 6:57 am
Your car has Active Stability Control.
the ABS component is managed by the ASC ECU try looking for articles there.
Cammo00
Postby Cammo00 » Mon May 06, 2013 10:29 am
Yer there conbined thats why I have no asc computer to read cause its wuth the abs :) The car is bsck in dydney now but yer wasnt sure if I could read abs cause in a mut3 on evoscsn I only had option of MutIII EFI (engine), MutIII AYC (active yoke control) and mut III CAN (Canbus) but no abs, I had mut 2 ABS but its for lancer 7-8-9 I need lancer x (10).so I coulfnt clear the abs after installing the module to see if it worked
Postby himynameisdaniel » Mon May 06, 2013 12:52 pm
It's on the CAN-C line so If you have a full MUT III you should be able to read it.
Software on the other hand may not be able to interpret. Have not tried with EVOscan.
If you can see AFS-ECU\CVT\ and the full steering wheel sensor then you should see the ASC...
Cammo00
Postby Cammo00 » Mon May 06, 2013 1:03 pm
No cant see steering angle sensor. I csn only see canbus and engine and active yoke control but being VR doesnt have active yoke control but I scaned it any way and had 4 code but wont clear.
Return to “Brakes”
