Removing middle section of front bar
Powderedhippo
Postby Powderedhippo » Fri Apr 26, 2013 1:11 pm
I've seen pictures of people blacking out the middle section of their front bar with vinyl though recently I saw a member on here with the entire middle section removed and meshed over though I can't seem to find it again.
I'm guessing this would have been done by a body shop but does anyone know if this would affect the car at all? From what I've seen I can't see that middle section doing anything important besides holding the number plate.
BUZZ_QWERTY
Postby BUZZ_QWERTY » Fri Apr 26, 2013 1:24 pm
Are you sure they removed the entire centre peice. Maybe it was just one of the EVO X peices you install of the existing centre piece.
anghel132
Postby anghel132 » Fri Apr 26, 2013 1:29 pm
That would be meee lol and it's all photoshop. But should be doable. (Russian's have it down pat).
Mate, you should probably have done a bit more of a thorough search - i know its a weird topic, but there are a few flying around.
bennieboi101
Postby bennieboi101 » Mon May 27, 2013 12:43 am
Doable maybe but not without reinforcing the front bar as in the centre area there are a lot of housings and supports.
im sure it could be done but would be tricky.
Postby Metalstrix » Mon May 27, 2013 12:31 pm
Its a bug collector xD
anghel132
Postby anghel132 » Mon May 27, 2013 12:36 pm
Options would be to create crossbars BEHIND the mesh
