Fast curing Sikaflex?
Postby lancerdarryl » Wed Apr 24, 2013 11:17 am
Be careful which silicon you use. RTV silicon has acetic acid in it (smells like vinegar) which promotes rust very quickly.Best to look forsomething neutral.Can you hold the bits on with masking tape or similar while your adhesive goes off ?.
Tweak
Postby Tweak » Wed Apr 24, 2013 5:20 pm
Miss Aussie
Postby Miss Aussie » Wed Apr 24, 2013 6:49 pm
Loctite 770, 403, 408 etc
Tweak
Postby Tweak » Wed Apr 24, 2013 7:46 pm
770 is just way overkill (great shit) but it will either melt the plastic or turn it brittle.
Most loctite stuff rely on a chemical reaction to cure and this produces alot of heat
Miss Aussie
Postby Miss Aussie » Wed Apr 24, 2013 9:07 pm
I've never melted anything lol
evolx08
Postby evolx08 » Wed Apr 24, 2013 9:11 pm
3M tape AND sikaflex 227 ftw
LaNcE
Postby LaNcE » Wed Apr 24, 2013 11:11 pm
lancerdarryl wrote:Be careful which silicon you use. RTV silicon has acetic acid in it (smells like vinegar) which promotes rust very quickly.Best to look forsomething neutral.Can you hold the bits on with masking tape or similar while your adhesive goes off ?.
shoot. which RTV are you talking about? ive used RTV to stick my spoiler on my challenger!
Postby lancerdarryl » Thu Apr 25, 2013 12:26 am
Dow Corning "Silastic" Brand is the most common one . If you still have the tube or cartridge that you used have a sniff if it does smell like vinegar I would be taking it off and using something neutral like sikaflex.
LaNcE wrote:[quote:2d25eba3e4=lancerdarryl]Be careful which silicon you use. RTV silicon has acetic acid in it (smells like vinegar) which promotes rust very quickly.Best to look forsomething neutral.Can you hold the bits on with masking tape or similar while your adhesive goes off ?.[/quote:2d25eba3e4] shoot. which RTV are you talking about? ive used RTV to stick my spoiler on my challenger!
