http://ezlip.com/
Got this product a couple of weeks ago! (For my sideskirts
Really accent's the skirts and makes the car look lower and with the flexible rubber it would protect it a bit to i guess!
Just thought id share (Will upload a picture asap)
-Carlos
EZ LIP - Universal Lip
- chunky9
Yeah ive been considering doing my sides with this stuff. I saw it on a silver ra somewhere, thought I saved the pics, but yeah it finishes the sides nicely
My progress thread: http://clubcj.net/viewtopic.php?t=13443
- Platinum Ace
- Zaphod
Very, very old thread Pat - last post was 01/03/13
If you are going down that track, have a look at Rhino Lip; similar but stronger (and stiffer) - EZ-Lip is a foam structure with a smooth outer surface, Rhino Lip is solid all the way through.
The EZ-Lip is therefore more flexible, but tears more easily - the Rhino Lip won't tear, but it's harder to get around tight corners...!
- Zaphod
You'll need to drill holes anyway - unless you're unbelievably lucky and never scrape a driveway or drive faster than 60km/h (don't forget that at high-speed, the air passing under your front bumper will try and peel the Ez-Lip down and off..).
You can just use self-tapping screws and wide (panel) washers th hold it all in place if/when it starts to peel.
Don't let me put you off, I'm going to do this on mine anyway, just as a 'scrape prevention'
