How do I implement my plan B?
Postby Metalstrix » Thu Jan 17, 2013 5:30 pm
Earlier this month (January) I ordered these strips.
I was going to use them originally as "Daytime running lights". But when I discovered the angel eyes, these strips became useless. I attempted to sell them. That wasn't very successful.
I was at work the other day and my colleague said "If you can't sell them, why don't you put it in the interior of your car? Maybe on the side of the door? Hook it up so when you open your door, the strips will light up."
I thought it was a brilliant idea. So I might do that instead. How can I go about this?
debonaire
Postby debonaire » Thu Jan 17, 2013 5:59 pm
Wire it to door light
Postby Metalstrix » Thu Jan 17, 2013 7:35 pm
I don't think there are any door lights in the 2008 VR lancer. Are there any guides on how to hook these strips up for the side door?
bunnishiwa
Postby bunnishiwa » Thu Jan 17, 2013 8:12 pm
By door light he means your dome lights. Maybe attach where you want, run the wire in to the door, through to the car, up on of the pillars and patch into one of the roof door light wires.
- Lowered on Kings
- Whiteline Rear Swaybar
Noli Timere Messorem
Fitter
Club Vendor
Club Vendor
Postby Fitter » Thu Jan 17, 2013 9:26 pm
I have light up scuff plates in my 2008 ES.
Earth wire goes to door switch and positive wire goes to constant power found behind passenger kick panel, thick red wire.
CLUB CJ CAR AUDIO VENDOR
2013 WORLD TITLE
2012 QLD State Champion
2008 Australian Champion
Postby SIX » Thu Jan 17, 2013 9:26 pm
why dont you attach them in you boot as boot lights ??
Cammo00
Postby Cammo00 » Thu Jan 17, 2013 9:53 pm
Lol I must be bit late? how big the LEDs strips? I'm looking at renewing my drl on front of mine as the silvon cover broke due installing and now is rusting. Looking for 600mm? but if you got plans for them that's awesome. I like the boot idea that six420 said
Love That Car. (cj-blue)
Alixxandar
Postby Alixxandar » Fri Jan 18, 2013 1:23 am
Am I the only one that finds it odd that the keyboard is the wrong way round?
Also, boot lights seems like the best idea, either that, or underneath your seats so it's sort of like "underglow for seats"
Postby Metalstrix » Fri Jan 18, 2013 8:24 am
bunnishiwa wrote:By door light he means your dome lights. Maybe attach where you want, run the wire in to the door, through to the car, up on of the pillars and patch into one of the roof door light wires.
OH I see. Lol. I'm such an idiot sometimes xD. Anyways, I probably won't have it on the door. Maybe just between the chair and the door.
SIX420 wrote:why dont you attach them in you boot as boot lights ??
Nah, I already have a light for my boot. No need to put 2 extra ones in :).
Alixxandar wrote:Am I the only one that finds it odd that the keyboard is the wrong way round? Also, boot lights seems like the best idea, either that, or underneath your seats so its sort of like underglow for seats
Lol my 1/4 of my keyboard is under the desk and it's slanted. So that's probably why it looks upside down. As for the lights, I won't do the boot. I'll attempt to put them between the chair and the door.
So hypathetically if I were to put them under my heat, what procedure should I take? Are there any videos or guides on how to do this?
Alixxandar
Postby Alixxandar » Fri Jan 18, 2013 10:30 am
metalstrix wrote: So hypathetically if I were to put them under my heat, what procedure should I take? Are there any videos or guides on how to do this?
I'd find a 12v switched power, and tap in to that. There's plenty behind your dash, and there's a signal wire for the head unit that I used for my amps signal wires.
The cables would run nicely behind the kick panel and scuff plates on either side. Be careful when removing the kick panel, as there's a round clip at the back (not sure the name of it) that's hard to see unless you know it's there.
As far as ground/negative goes, any bare metal that you can attach a ring connector to will do.
Return to “Interior”
