Boost gauge install
vermilioN
Boost gauge install
Postby vermilioN » Sat Dec 15, 2012 3:32 pm
Trying to install my mechanical Boost gauge but I cant figure out where is a good place for the hose to go through the firewall.. No idea what im doing! I want the gauge to sit on my dash on the right of my steering wheel.
Postby SAM-24A » Sat Dec 15, 2012 3:49 pm
Mitch ... you say
"No idea what im doing!"
.... *noidea*
You really should plan & research such mods with other members who have done similar before you attempt them.
It helps prevent any unnecessary & unexpected dilemmas that might occur part way through the job .... :roll:
Try-It next time .... :wink:
Speedie
Postby Speedie » Sat Dec 15, 2012 3:51 pm
I used the grommets behind the front wheels that go into the chassis rail then out by the kick panels
Speedie
Postby Speedie » Sat Dec 15, 2012 4:01 pm
Or you've got the one by the ABS unit behind the air box
Postby sleeper » Sat Dec 15, 2012 4:19 pm
i drilled a hole in the firewall then up through the A pillar
bunnishiwa
Postby bunnishiwa » Sat Dec 15, 2012 4:23 pm
Drilled a hole.... Brave man.
If you pull the carpet behind the accelerator pedal away you will see a grommet that goes into engine bay. Cut appropriate hole in grommet, feed tube through, put grommet back in (i used flat head screw driver). Feed tube to wherever and use cable ties in engine bay
- Lowered on Kings
- Whiteline Rear Swaybar
Noli Timere Messorem
Postby sleeper » Sat Dec 15, 2012 4:27 pm
no not brave, i checked the brake reserviour wasnt behind it :P
rokpapaziz
here
Postby rokpapaziz » Sun Dec 16, 2012 6:57 am
You can try here. Not sure if yours will have the lining that covers that area. Mine doesn't.
Image[b]
Return to “Interior”
Users browsing this forum: Bing [Bot] and 3 guests
