running coilovers on hightest damper setting question
Postby lancerdarryl » Fri Nov 09, 2012 9:34 pm
Short answer--No, but you will need a kidney belt and your dashboard will fall out
Dire
Postby Dire » Sat Nov 10, 2012 1:53 am
Yeah I believe it will put a higher strain on them, but coilovers should already be more heavy-duty than stock so it'd be alright in most cases.
Theres no point running max all-round though... FWD cars benefit from having the back a little harder than the front :)
Dire
Postby Dire » Sat Nov 10, 2012 2:09 am
I have BC racing ones too :)
And yeah, I run the back very hard haha. 25 or something. Fronts are more like 15...
I don't care about comfort at all when I'm by myself. I find maxing the dampers makes the car skittish and jittery over bumps though.
Dire
Postby Dire » Sat Nov 10, 2012 2:16 am
I have a rear one on order haha.
squala
Postby squala » Thu Nov 15, 2012 7:27 am
larrywatson wrote:yeah, i wouldnt care about confort either, the way i see it is if you buy coilovers you buy it to make it stiffer and low, lol. so why put dampers on soft, defeats the purpose lol. maybe, front and rear swaybars to make it more go kart, that might stiffer up abit aswell? have you done sway bars?
I'm basically interested in coil-overs because of better flexibility. For daily drives, I like the front to be a bit lower, then when there's a long family haul, the rear will be at its highest height setting to reduce squatting. And of course, the car would be better at the track.
7 airbags
6-speed SST
5-star safety
4-wheel drive
3-diamond badge
2 overhead cams
1 awesome ride
Dire
Postby Dire » Thu Nov 15, 2012 2:19 pm
larrywatson wrote:coilovers are louder then springs
Not really... Unless you set them hella hard :P
Dire
Postby Dire » Thu Nov 15, 2012 2:29 pm
Still in the post... Hopefully here before the weekend :roll:
Users browsing this forum: No registered users and 90 guests
