Knocking/Tapping noise at Idle - Cost to fix?
Postby aspir3 » Tue Oct 30, 2012 11:17 am
It could be many things that cause a tapping noise.
As for warranty on the drive train is for only 100,000km for the original owner. You cant sell the car with the extended warranty.
The problem could be a few things. Regular issues are noisy injectors, airconditioner or idle pulley bearing. These things are very hard to identify and often only a trial of replacing one part at a time. A good mechanic or a Mitsubishi dealer will be able to find and fix the problem. Expect between $100-500 to fix the problem/s.
The first thing I would do is empty the fuel tank then put 10 litres of 98ron fuel and a bottle of injector cleaner in with it and go for a good drive around the hills making sure you open the throttle all the way as much as possible through all the rev range.
tadz0rz
Postby tadz0rz » Tue Oct 30, 2012 11:45 am
Yeah it is the carbon canister, i took mine to have a look at and they said its just due to the design of the carbon canister, just has a loud valve in it apparently.
You can get it replaced however i dont think they've changed the design yet
Cammo00
Postby Cammo00 » Tue Oct 30, 2012 12:21 pm
I have hear a nock noise in mine too and in other cj lancers that I have worked on too I can hear it in idle when itsdead quiet. It's more like a ,, put put,, sound do no what it is. Good luck
Love That Car. (cj-blue)
mickyoz
Postby mickyoz » Thu Nov 22, 2012 11:58 am
Mine is the same too, if it is the carbin canister, any info on costs to do this? My ES is on 5 yrs old now, so wouldn't hurt to put something new.
lantourismo
Postby lantourismo » Sat Nov 16, 2013 8:44 am
Noticed this with mine also, I remember my old CE was noisy at idle I'm the same way I get the impression it's a design common with mitsubishi engines
Return to “ClubCJ Talk”
