100000k service
redlancer08
100000k service
Postby redlancer08 » Fri Oct 26, 2012 10:42 pm
What to service?
chris
Postby chris » Sat Oct 27, 2012 10:24 am
Easy check your service book
Tarquin
Postby Tarquin » Sat Oct 27, 2012 11:06 am
90k should have been the bigger service. 105k isn't that bad...
- CCJ Premium Member #0015.
Tarq's Paintshop
Kal777
Postby Kal777 » Sat Oct 27, 2012 11:24 am
If you havnt done the 90k service then there is a lot. 100k would be 18 point safty check, oil, cab filter, plugs if not already done, trans fluid if not already done, and inspection of all other fluids and drive belt. Also the 4B11/12 may need a valve clearance check at this point but it is only required if there is noise comming from the engine.
redlancer08
Postby redlancer08 » Sun Oct 28, 2012 3:39 pm
what about timing belt?
Kal777
Postby Kal777 » Sun Oct 28, 2012 5:22 pm
the 4b11/12 has a timing chain that does not need replacing under normal conditions. the chain should out live the engine.
Dire
Postby Dire » Sun Oct 28, 2012 5:58 pm
READ THE MANUAL
bongo
Postby bongo » Sun Oct 28, 2012 6:34 pm
Does anyone know the price for the 90000 km service? I was quoted $1700!
BlueWRX
Postby BlueWRX » Sun Oct 28, 2012 6:35 pm
I've been quoted $240
bongo
Postby bongo » Sun Oct 28, 2012 6:38 pm
Sorry, forgot to mention ....ralliart.
rokpapaziz
Postby rokpapaziz » Mon Oct 29, 2012 9:47 am
I think there is an ACD fluid change as well. I'm coming up to the 90K service too. Doesn't look cheap
big_d
Postby big_d » Fri Dec 14, 2012 10:05 am
Here is a list of what is carried out for the 105,000km (or B Service).
I just had the 90,000km service done, and it's about the same.
Spark plugs need replacing in the 90k service, and they are about $40 (NZD) each.
LUBRICATION AND HOIST INSPECTIONS
Renew engine oil and filter
Clean battery, terminals and smear with petroleum jelly
Check drive line oil levels
Check drive shaft gaiters for damage or deterioration
Adjust tyre pressures including spare
Check radiator and ultra long life coolant concentration*
Check power steering, brake, clutch, screen washer fluid levels and additive
Clean door drain holes
Change transmission oil / fluid (and auto trans filter) at 105,000 km
* Drain, flush and refill with ultra long life coolant at 48 months or 105,000 km whichever occurs first
UNDER BONNET INSPECTION
Check brake / clutch master cylinder
Check power steering fluid
Check all external drive belts
Check battery
Check engine coolant level
Check all brake, fuel, power steering and other pipework for security and clearance
Check transmission oil level
Check radiator hoses
Check screen washer bottle level and additive
UNDER BODY HOIST INSPECTION
Check steering linkage (include seals and boots)
Check suspension balljoints and dust covers
Check suspension system
Check (visual) tyre wear (alignment)
Check exhaust pipe connections for leakage and alignment
Check under body damage
BRAKES
Check disc pads and brake drum linings for wear
ROAD TEST AND CHASSIS
Check operation of instruments / equipment and accessories
Check engine performance and operation
Check gearshift and drive line performance
Check service and park brake performance
Check suspension
Confirm no diagnostic codes are present with MUT tool
