Compressor replacement
pugengbagsik
Postby pugengbagsik » Fri Oct 26, 2012 4:26 am
Hi guys,, need help on how to uninstall and installing 08 lancer gts compressor. Thx
Postby aspir3 » Fri Oct 26, 2012 9:17 am
In Australia you need specialized equipment to remove the gas before we can unbolt the compressor.
Try to download the workshop manual which should help you remove the compressor.
pugengbagsik
Postby pugengbagsik » Fri Oct 26, 2012 3:09 pm
Thx aspir3 for the reply, where can i download the workshop manual thx....i couldnt find it.."
Kal777
Postby Kal777 » Fri Oct 26, 2012 6:19 pm
it would be better to pay a professional workshop to do the job. after you degas the system you would need to re-gas it again which again requires special equipment.
