ELECTRIC CARS ... Fast or !!!
Postby SAM-24A » Tue Oct 23, 2012 8:10 pm
Wanna Drive a Quick Electric Car .... Link: RIMAC - Concept 1 .... :)
Began as a determined dream by a young Croatian guy (Mate Rimac - Founder of Rimac Automobili) who used his old M3 BMW (Evaluation Vehicle) as a Test/Experimental Vehicle.
There is plenty to see & read under the "Concept 1" drop-down box.
Performance
Power output: 1088 hp
Torque: 1600 Nm from 0 to 6500 rpm
Acceleration: 0-100 km/h (0-62 mph) 2,8 seconds
Range: up to 600 km (realistic range – 500 km)
Braking distance: 31.5m (100-0 km/h)
Lateral g-force: 1.4 g
Efficiency: 140-550 Wh/km
40 kW on-board charging
100 kW fast DC-charging
Weight-to-power ratio: 1.79 kg/hp
Weight distribution: 42% front, 58% rear
Dimensions
Total length: 4548 mm
Total width: 1997 mm
Total height: 1198 mm
Ground clearance: Rear: 115 mm, Front: 105 mm
Wheelbase: 2750 mm.
Dry weight: 1950 kg
Battery-Pack
Lithium-Iron-Phosphate (LiFePO4) chemistry
Configuration: 1400 cells - 200 series, 7 parallel
Voltage: 650V nominal
Capacity: 91 kWh
Cooling: Freon (gas) with high-voltage heat pumps
Milled aluminum and sheet aluminum housing
Rimac Automobili Active Battery and Thermal Management Systems
Several layers of redundant safety and protection systems
Chassis
Carbon fibre monocoque with integrated battery-pack
Carbon fibre sub-frames (front and rear)
Carbon fibre crash structure
Front and rear suspension: Double wishbones, fully adjustable, pushrod operated.
Electronically adjustable ride height.
Fully machined aluminum uprights and wishbones
Propulsion System
Rear: Rimac Automobili D-PM-OC-600 – high speed dual permanent magnet oil cooled motors, 600 kW peak, 10.000 RPM, up to 97% efficiency
Front: Rimac Automobili D-PM-OC-400 - high speed dual permanent magnet oil cooled motors, 400 kW peak, 10.000 RPM, up to 97% efficiency
Dry sump lubrication
Milled aluminum housings
Reduction gearbox ratio: 3,5
Steering
Rack and pinion electrically power assisted steering.
Brakes
Front brakes: Ventilated ceramic discs Ø 390 mm, 36 mm wide.
6-piston calipers, power-assisted.
Rear brakes: Ventilated ceramic discs Ø 380 mm, 34 mm wide.
4-piston calipers, power-assisted.
Up to 800 kW of regen-braking (adjustable)
Safety Systems
Front and side air-bags
ABS
Torque Vectoring with stability function
Safety disconnect systems in case of crash
Multiple ECU architecture for monitoring of safety-relevant electronic systems
Body
Full carbon-fibre body.
Seffy
Postby Seffy » Tue Oct 23, 2012 8:17 pm
Mr Charisma
Postby Mr Charisma » Tue Oct 23, 2012 8:24 pm
Ummm wow....
Love that car!
Dire
Postby Dire » Tue Oct 23, 2012 8:48 pm
The only downside I can see in those numbers is the weight. But with 1.4g lateral grip who cares.
Even the range is good. Although charge times make electric cars poor track-day cars (by my maths at max output its range is 165km not counting regen braking). I wonder if you need to worry about overheating in a car like this too.
Quite amazing though, and exciting for the future, although what will the world be like if most cars were near-silent :(
Leez
Postby Leez » Tue Oct 23, 2012 9:25 pm
God damn that looks sexy.
Users browsing this forum: No registered users and 160 guests
