grimmspeed 3 port actuator
Postby sleeper » Fri Oct 19, 2012 8:30 am
hi guys,
which grimmspeed would u recommend for my std turbo RA (i assume thats the best and easiest to fit?) and where to buy it?
Speedie
Postby Speedie » Fri Oct 19, 2012 8:35 am
Are you referring to the 3 port boost solenoid? Are you going to retune for it?
Postby sleeper » Fri Oct 19, 2012 8:38 am
thats an affirmative to both questions Dan :)
this one?
http://tinyurl.com/9tectow
Speedie
Postby Speedie » Fri Oct 19, 2012 8:41 am
you'd wan to get the electronic one as the ECU does the best job at controlling the boost. Which you can get off Boomba racing http://www.boombaracing.com/evo10.html
bunnishiwa
Postby bunnishiwa » Fri Oct 19, 2012 10:23 am
This one
http://www.grimmspeed.com/catalog/produ ... cts_id=163
Direct from the horses mouth as such, and $10 cheaper to boot
- Lowered on Kings
- Whiteline Rear Swaybar
Noli Timere Messorem
Speedie
Postby Speedie » Fri Oct 19, 2012 12:03 pm
Glenn
Postby Glenn » Fri Oct 19, 2012 12:28 pm
new tune in the works steve?
Speedie
Postby Speedie » Fri Oct 19, 2012 12:35 pm
Wonder if hes asked Sue yet
Beeble
Postby Beeble » Fri Oct 19, 2012 12:43 pm
or buy one locally for $135 from Tuspeed or RTR for instance
or 125 from carmodsaustralia
etc
http://BeebleTune.com
Postby sleeper » Fri Oct 19, 2012 1:44 pm
no, i havent asked Sue yet.
shouldnt need that much of a tune should it?
just the actuator levels?
i read some where on evom or here that its no biggie.
Beeble
Postby Beeble » Fri Oct 19, 2012 2:11 pm
the tune is super easy but drive like a grandma once you install it or you'll overboost like crazy until you get it tweaked
Postby sleeper » Fri Oct 19, 2012 2:16 pm
thanks beeble, will do, although i probably wouldnt install it till i got the tuning end sorted :)
there wouldnt need to be a dyno would there?
Beeble
Postby Beeble » Fri Oct 19, 2012 2:19 pm
nah you can log it on the street if you've got somewhere safe to do it.
Postby sleeper » Fri Oct 19, 2012 2:22 pm
ok, i didnt think it needed logging, thanks.
