Thinking of modding car- warranty issue
DaReeD
Postby DaReeD » Fri Oct 05, 2012 1:25 pm
Hey guys I have a my12 lancer vrx bought it brand new a couple of months ago.
I'm planning to put on a cold air intake, change the hood, rear bumper to have diffuser and dual exhaust, new rims and lowering the car.
Does any1 know if modding it with the stuff listed above would void the warranty of the car?
Also any suggestions where I could get cheap parts in Sydney?? :)
Fitter
Club Vendor
Club Vendor
Postby Fitter » Fri Oct 05, 2012 1:26 pm
Warranty can only be voided if an aftermarket part can be proven to have caused a fault directly from its ap
CLUB CJ CAR AUDIO VENDOR
2013 WORLD TITLE
2012 QLD State Champion
2008 Australian Champion
Fitter
Club Vendor
Club Vendor
From its application
2013 WORLD TITLE
Alixxandar
Postby Alixxandar » Fri Oct 05, 2012 1:54 pm
They can also void it if it was installed by an "unlicensed technician" like a DIY job. They'd use a justification a long the lines of "Other parts could have been tampered with or damaged, resulting in the failure of [affected part]"
That happened to a mate of mine.
Latino_Ralliart
Postby Latino_Ralliart » Fri Oct 05, 2012 2:15 pm
Quick answer is yes. If one of the mods is responsible for a part failing then you lose the warranty on that only.
So if you lower you car and shocks die, your not covered.
The Air intake for some peculiar reason damages your engine then your on your own.. IF they can prove it was the modifcation that was the cause.
Bottom line you want warranty don't modify.
